Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th February 2011, 09:29 PM   #11
If you want to completely follow the service manual, the laser current should be tuned (via 4.7K pot) so that voltage across a 4.7K resistor for HFin to TDA8808 to be 50mV when playing pressed CD.
You should first check the laser current and then fine tune the focus. The laser current can be measured by the voltage across a 12ohm resistor near CDM-1 flex cable plug on servo board. You can tune it up a bit if needed, but over 65mA means your laser is about to end the life.
After the laser current is tuned, the focus can be tuned (via 22K pot) to make FElag pin of TDA8808 to be 400mV +- 40mV.
Old 6th February 2011, 06:41 PM   #12
Send a message via AIM to michael_nipomo Send a message via MSN to michael_nipomo Send a message via Yahoo to michael_nipomo
Thanks everyone. Will go away and try the things you have recommended!! If the Lazer is bad or weak does anyone know where to purchase another?
Old 7th February 2011, 01:59 AM   #13
The laser will not be bad. I have never, ever seen a CDM-1/1mkII laser go bad or even get weak.
Old 9th July 2011, 05:12 PM   #14
Default Philips/Marantz CD80 Remote Control
You Philips & Marantz CD80 Guru's -- Does anyone out there have any information on the Remote Control for those units? Will the Marantz CD80 Remote Control work with the Philips CD80 CD Player and vice/versa. Does anyone have the Hex Codes for the Remote Controls or could tell us where to get the Hex Codes? Does anyone have an extra remote that they could loan so that we could get the Hex Codes?
Old 9th July 2011, 05:33 PM   #15
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Philips/Marantz use RC5 codes for remote control. Any cheapo all in one remote that has preprogrammed audio codes will usually work them OK
A simulation free zone. Design it, build it, test it.
Old 9th July 2011, 06:42 PM   #16
One of the additional features of the Philips/Marantz CD80 Remote Control is the Control of the Alps Potentiometer in the CD80. The RC5 Codes do not control Volume. They do control some standard features but not volume nor other features like the Repeat & Random functions. Not being able to go directly from the CD Player to an amplifier is a Major problem for us!!!
PHILIPS CD80 cd player $1 homemade Swap Meet 0 28th March 2007 01:43 AM
Philips CD80 tray problem? HH Digital Source 35 2nd August 2006 01:06 PM
Philips CD371-dead,but? ZuMbAiU Digital Source 3 1st May 2006 01:36 PM
W: Dead Philips CDP Thomas Swap Meet 0 18th July 2004 10:51 AM
WTB: Marantz/Philips CD80 patwen Swap Meet 3 7th August 2003 04:05 AM
Page generated in 0.08757 seconds (74.12% PHP - 25.88% MySQL) with 10 queries
