Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th November 2009, 11:35 AM   #21
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Try plugging in and turn on while you keep pressed play and stop.
Old 18th November 2009, 11:29 PM   #22
Default Steve
Hi guys,
I have error message10 radial in service mode, any ideas.
When I press play sometimes the disc will spin (at speed) but not recognise a disc (display just shows disc) other times it sounds like a starter motor, obviously on a much smaller scale.
I have recently replaced opamps and mains cable.
thanks in anticipation of help
Steve
Old 19th November 2009, 08:02 AM   #23
Fidelity Audio's Avatar
Have you fitted any clocks?
When in test mode 01 and you move the disc with your finger does the laser hiss?
Brent
Old 19th November 2009, 07:10 PM   #24
Default Steve
Thanks Brent,
Laser does hiss. I have installed a rockclock recently although it was working fine until I opened everything up to install new opamps. I will recheck all solder joints here.
any ideas?
Steve
Old 19th November 2009, 10:44 PM   #25
Default Steve
Have figured out the problem,
I had ruined the connection between the clock input and the DAC now hard wired.
The disc now spins and plays however I get no sound at all. I have just changed the opamps for ad843knz.
Steve
Old 20th November 2009, 06:06 AM   #26
Mooly's Avatar
What were the original opamps... you haven't replaced dual with single ?
If it played OK prior to replacing these then it must be something you have done. Check the supplies to the opamps and then you need to trace the signal from the DAC through the opamps tp the output (scope)
Old 20th November 2009, 07:25 AM   #27
Good news on the reading of discs. The hiss confirmed the servo was running.
The opamps well you have fitted single types instead of duals.
Brent
Marantz PM 66SE KI Signature - volume control fault sztockmann Solid State 6 24th September 2009 11:29 PM
WTB Marantz CD63/67 Mindcrime Swap Meet 6 30th January 2009 12:35 PM
Marantz DVD player power supply fault? slimecity Digital Source 1 1st January 2009 09:57 AM
Marantz CD63 palucca Digital Source 3 27th September 2008 11:10 PM
Marantz cd63: PWM to DSD ? ash_dac Digital Source 0 24th February 2006 09:59 PM
Page generated in 0.08879 seconds (73.88% PHP - 26.12% MySQL) with 10 queries
