| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Thread Tools |
#21 |
Hi ilimzn,
due to lots of work still struggling through your posts in the CD63 mod thread..... asolutely interesting!!! Deep respect to your knowledge and your disposition to share this!!! Will be back soon with a new post. Have of course still a few questions. Most regarding LED shunts and grounding issues....Regards Ernst |
#22 | ||||||||
Good Evening Ilimzn,
I've seen clocks with a cap at the output, I thought about implementing one as well. Quote:
Found a pic of your spareplayer CD1020. Looks nice!! Just had a look, which DAC your Sony has. Would habe been happy, if it were a V24+ box, but wasn't. I have got an old SCD XB940 (too many inductors for you) laying around which is waiting for some mods. Accidently yesterday I found some really good info about how to get out the best of its DAC here in the forum in a very short thread. Will have a lot of work and fun with this player as well, but this is another and further away story....Btw, one thing the 940 shares with the Marantz players are the groundloops. I'll look after them in both. Quote:
![]() I also found this an many more in the thread, you mentioned. Probably this is the longest thread, I've ever seen. Never knew, that these players were/are soooooooo popular. I found the description of your grounding approach (extremly interesting - for other projects as well, like amps aso), your using the original transformer approach (clock voltage should be connected to analog windings), your way of using existing pcb layout for your modification. You mentioned a few elder opamps, that should sound very nice in this particular circuits. You mentioned also, that I could use my HDAMs. Would you recommend using just the last HDAM stage and replace the other ones with opamps or do you think, they are ok in these positions as well? Since I got so much info, I'll start this project by this or the next weekend. Step by step. Devil is in details, questions will be raised. Cheers Ernst |
#23 | ||||
In the pic attached, there are 2 versions of simple shunt regulation, the left one is with the TL431 shunt regulator chip, the right one with a series of LEDs. Keep in mind that actual component values are just representative, so in the real application should be tailored to the actual application - in particular the current source, and the capacitor(s). As drawn, the TL431 is set to 5V and the LED chain is 2x red and one IR LED, approximately 5.2V or so at the given current. There are 3 parts to each verison, denoted by colored rectangles. The reddish part is the actual load of the regulator, i.e. DAC, clock, OP-amp etc, which also includes it's own load (filter network, clock network, actual amplifier, respectively). The green part is the shunt element itself - the one keeping th DC voltage constant regardless of current. In actuality, this action is not perfect, so voltage changes with the current, but the changes are very attenuated - in essence, it exhibits very low dynamic impedance. Also, a minimum and maximum current limit exists for each real element. The yellowish part is the current source. In it's simplest form it can be a simple Idss connected JFET (gate to source directly conencted, and selected by resulting current according to need). A small damping resistor or even feritte bead inductor in series is a good idea to prevent HF coupling through the parasitic capacitance of the current source. The current source passes the same current regardless of the voltage across it, in theory. In actuality, the current varies very little with voltage changes. In essence, it exhibits very high dynamic impedance. Again, a minimum and maximum operating voltage exist for actual current sources. Although it is not apaprent if one would look just at the schematics, this combination of elements forming a complete shunt regulator, is capable of separating the DC and AC current loops for the load and power supply. Because the shunt element exhibits (idally vanishingly) low dynamic impedance, and is across the power supply pins that power whatever is supplying the signal to the load, so any load current has to appear across these pins as well, and current always passes through the path of least impedance, it will have to pass through the shunt element. Because 'dynamic impedance' literally means AC impedance, and these elements work to practically DC, all load current only stays withing the AC current loop as marked on the schematic. In turn, because the current source is a very high dynamic impedance, any AC currents will not pass around the DC loop, which includes the actual power supply, pre regulation (Between AVcc and AGND). Of course, in reality, the current splits between the AC and DC current loops so there is always a residual of the AC current inside the DC current loop, but this residual is only as much as the ratio of dynamic impedances of the current source versus shunt element - the first being on the order of hundreds of kohms, and the second on the order of a few milliohms to a few ohms. So, the residual is a greatly attenuated version of the actual load current, or any current that appears between AVdd and AVss - easily 4-5 orders of magnitude if good layout and design is used. It could be said that the DC current loop which is defined by the current source, only initially charges the capacitor in the shunt element until the semiconductor part limits the voltage on it. From there on, current is circulating around in the AC current loop, with the DC current loop only covering losses. A non-obvious aside is that AC will not pass along a common path needed to connect all ground points, i.e. AGND and DGND, even if they are ultimately conencted to the same non-regulated power supply, and even if there are multiple paths. In reality, of course, the AC component will be strongly attenuated. (See dotted line in the DC current loop arrow). This means that if there is a common path for varius current returns, because the AC components in them are strongly attenuated, they have that much less chance to interfere with one-another and leak into power domains where they do not belong. The fact that they are creating a constant voltage drop (DC) across various ground paths is of little consequence as actual signals of interest are dynamic, and not static (of course, as long as voltage drops do not become excessive but then the device would not operate correctly in any sense anyway so this would be a fault rather than an imperfection). Finally, most series regulators do not have this advantage, as they require some sort of capacitor at the input, which then connects the unregulated input via cap to the ground, alowing AC current from the unregulated input (due to ripple or nosie) into the local ground and from there along a ground return path to the unregulated source. In other words, now you gat an AC voltage drop along this path - or paths, which means that the ground reference will not be the same along the path, which in turn means that this AC component is in some amunt or form injected into various places in the circuit where it does not belong. That being said, there are regulators that avoid this - the LM317/337 is one common example, but you have ti apply them carefully in this fashion. however, the concept is much more esily explained on shunt regulators as from the standpont of the unregulated supply, they look like a DC current sink, i.e. a two-pin element. Quote:
Regarding tubes, it is actually easyer to do a simple balanced tube output than an unbalanced one, if the input to it is a balanced signal. For an unbalanced (se) output you need to implement a fully balanced circuit with both sides used as an output, but you take only one signal from one output, while you put a terminating ipedance equal to the output load on the unused outut of the tube stage. If that cannot be done, the tube stage gets more complicated as it needs followers on the output. The reason is that the load on the the output of the simple version needs to be equal on both sides or conencted between the outputs in order to equally infuluence both halves of the circuit, in particular the gain. If teh output load can be unbalanced, it has to be 'isolated' from the diff amplifier so that it does not influence it's operation, which complicates the circuit. Last edited by ilimzn; 23rd October 2009 at 05:49 PM. Reason: Pic attachment |
#24 | |
Ilimzn,
Thank you for the LED shunt circuit and description!! ![]() My player output is single ended, and adjacent equipment is SE as well. So the rebuilt player should be SE again. The circuit you posted - with the three opamps - seems to be perfect for me. My player has got three HDAMs per channel. In the pic I added, you can see circuit of CD6000. Instead of the shown 4 opamps my CD6000OSE has got the four HDAMs, I recently posted. So if you consider these appropriated, I'd prefer to use these. Otherwise I would be able to find some opamps in my box. i.e. LM833, 2604, 627 (know, this one is just single opamp). Also I would like to use tubes in the SE outputmode. Quote:
Regards Ernst |
#25 |
It should be perfectly fine to use the HDAMs instead of OPamps, as the HDAM is actually a discrete OPamp. You should be able to use the circuit I posted almost with no modification (save for the LO/RON and RO/LON dual connection via resistors to the first cap in the passive filter).
If you want to use OPamps instead, the best results I had were with FET input OPamps in the first stage, and bipolar in the second stage. I've tried a number of combinations and finally settled on AD712 in the first stage (one dual OPamp per channel) and LM833 (one op-amp per channel, so a single LM833 is shared across channels) for the second stage. A current sink forcing the LM833 into class A improved the sound subtly, to my ears. Second best was LT1057 (if i am remembering my numbers correctly) in the first stage. A number of people modifying CD63s have said that modern OPamps sound better than the HDAMs, but as the CD1020 does not have HDAMs, i did not have a chance to check this. I will try to scale the filter components for larger caps when time permits... Last edited by ilimzn; 26th October 2009 at 01:10 PM. Reason: Typos corrected... |
#26 | |
I'll try first the HDAMs, since they are there. Probably there are worse things. Just came down from my bench, where I implemented a new clock directly to the two DACs, and leading the clock signal from one DAC to the separation chip. Was a bit scared , but it worked ![]() ![]() Could just hear via headphone so far, sound seems to be ok, but I noticed a click noise between the tracks, which was not there before. Any idea? Read about this that it can happen when NOSsing a TDA1541 player, but this is another story........Anyway I would like to get rid of this. So far I have no idea, I even do not know if what I've done regarding the clock is the reason therefor or if it happened accidentally. Next steps are looking after ground loops, and trying to swap to the proposed output circuit by keeping as much as possible parts on their location. Lets see. Modifying the PSU will take some time... Cheers Ernst |
#27 | |
#28 | |
But then I tried this on the hifi system and noticed, that this noise can just be heard via headphone. Nothing left at the hifi system So I tried both, inverted and non inverted clock on the separation chip and found out, the not inverted clock version sounded less ringing in the heights and provided a much better stage. The inverted version was much more narrow. So far so good ![]() In the meatime I was several times appalled - always when there a mistake happened when I tried. The CD drive made unpleasant noises, display reported error...... Fortunately now everything is working again and better than before. Sound is softer, stage is wider with the external clock. As expected from after reading a few threads about that. For me a good step. I read, clock cables should be a short as possible. Since this is not really possible in my case, would it help to use shielded cable? Cheers Ernst |
#29 | |
If you look at the original tracks on the board, they put in a resistor in series between the output of the gate array and the inputs to the DAC chips - for exactly the same reason. |
#30 |
Well, some news to show that there something is going on and I'm not too deedless
![]() Have ordered most parts I'll need for the mod. Resistors, caps, transformer, opamp and -- I'm looking forward getting these parts within some days. Plan is now: External clock and DAC clock supply get a separate transformer. External clock has got TL431, which is considered ok. DAC clock supply gets few mA CCS plus LED shunt, as shown here and written about in the giant CD63 thread. Maybe I let this transformer feed the Analog DAC supply as well, also with CCS and LED shunt. Clock lines will get some 50 to 100R resistors. PSU for outputstage will get another transformer (25VA, 2x12VAC), which I found in my box. This will be connected to the board just like the original transformer. Caps and regulators will stay. After that CCS plus LED shunt will be new there. Voltage reduction should not be an issue. Matching the LED chains will need some effort. Lets see. I'll try to separate all different grounds (which means cut some traces or wire bridges and isolate (replace with isolated) all the chinch connectors) and let them meet just in one point between close to the DACs. Original transformer will just have to power the digital section and the CD drive. I'll add a CCS plus shunt for the digital DAC psu as well. First, I thought, I should let the original transformer drive the analog outputstage, but I think, feeding the digital section including CD drive by a new transformer would be more difficult. Any comment? Analog output filtering will be modified after Ilimzn's plan. Does look good, and in my case is rather easy to do, since the three stages per side are already there. Ilimzn has mentioned that. I'll set a small raster pcb in place with all the new parts between DAC and HDAM. I'll also try out the AD712, since it is easy to exchange vs. HDAM if an Opamp socket is soldered in. The external clock I already fixed on the right sidewall of the player. For a small transformer there is still room enough. The second new transformer will sit somewhere rear left, close to the powercable inlet. I assume, my old CD6000 will sound different then ![]() I'll let you know. Ernst |
| Thread Tools | |
| Help with PSU for tube DAC output stage | luvdunhill | Tubes / Valves | 1 | 6th May 2008 09:10 AM |
| Tube output stage for DAC | ackcheng | Tubes / Valves | 10 | 14th January 2004 12:13 PM |
| dac tube output stage..pls help. | tone | Tubes / Valves | 80 | 25th March 2003 06:13 PM |
| need help on tube output stage.. | tone | Digital Source | 2 | 19th March 2003 04:52 PM |
| Page generated in 0.26145506 seconds (92.02% PHP - 7.98% MySQL) with 11 queries |
