S/PDIF vs. AES/EBU - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd September 2009, 06:29 AM   #21
jan.didden's Avatar
Originally Posted by bordins View Post
This depends on how the DAC deals with imperfection of the signal or transmission-induced noise. If the DAC recovers the embedded clock of AES/EBU or S/PDIF, then it is highly likely that the reconstructed analog waveforms will be different, hence sonically discernable.
[snip]
Indeed. There was an AES paper by Hawksford and Dunn "Is the AES/EBU interface flawed" where they showed that if the DAC recovers the clock from the data, the jitter is even dependent from the bit pattern, meaning the jitter depends on the music!
That lead Benchmark Media to develop their 'zero jitter' DACs where you have a super clean local clok that runs on its own, and a large digital buffer. The digital stream fills the buffer and the DAC reads it out with its own super-clean clock. No jitter. No cable issues.
There are others that do the same, its just that I know the Benchmarks (have no affiliation with them) and their very affordable price. You typically find them in studio's for monitoring the recordings you are going to buy later
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 22nd September 2009, 08:22 AM   #22
ASRC dac like benchmark have jitter spectrum thats very pure. An ASRC is short FIFO buffer followed by interpolation . One previous post said that the jitter cross coupled thru the FIFO buffering some of those players had. Thats interesting. Maybe you need 2 FIFO .
Old 23rd September 2009, 07:58 PM   #23
CosmoA is offline CosmoA  United States
Banned
Default SPDIF in pictures
The Benchmark DAC has a 50 ohm BNC connector (for a 75 ohm interface)followed by a couple of widely space wires connecting it to the PCB (high characteristic impedance)that also acts as a large loop area to pick up RF noise in the DAC. Stick a RCA to BNC adaptor in there for your favorite RCA connectored digital cable...
Gee I wonder why you can't here decent digital cable differences. Yes I'll bet they use resampling!
These people have the engineering talent to do better than this for the SPDIF interface, it is sad. This is pretty typical for ever high priced DACs.
Old 26th September 2009, 08:45 AM   #24
bordins is offline bordins  Thailand
I guess it is inside the metal enclousure of the DAC so it is considered "RF-safe". The RF inside would be relatively low, and the short cable distance can tolerate it. BTW, the torroid is much furthur away.
SACD over S/PDIF Iain McNeill Digital Line Level 4 1st September 2008 05:27 AM
S/PDIF Questions ak_47_boy Digital Source 0 31st December 2007 01:41 AM
S/PDIF Optical to S/PDIF RCA Replacement PrecisionAudio Digital Source 2 11th February 2007 09:35 PM
S/pdif borges Digital Source 9 5th March 2005 12:22 AM
How should I go about running S/PDIF for 10m? jlanng Digital Source 3 28th November 2001 10:13 AM
Copyright 1999-2017 diyAudio
