Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 10th September 2009, 11:03 AM   #1
tiefbassuebertr's Avatar
Default Starting cross reference for LSI processors and display drivers of cd player models
By service of older high quality cd players the so called "cross reference lists" are often very helpful.
Concerning optical pick up's (laser unit) and digital to analog converter IC's there are a wide range of weblinks. Here are some examples:
http://www.vasiltech.nm.ru/files/cd-...ransport.htm#B
http://www.dcaudio.kgb.pl/dac.htm
CDM vs Player Make & Model List
http://www.marantzphilips.nl/index.asp?strPage=Daclist
But regarding the other cd player LSI devices (e. g. PCM decoder, servo processor, operating processor, display and driver) I don't find comparable weblinks. Therefore I have create by my own website http://www.tiefbassuebertragung.de/49628.html
the topic "CDP-Service"
In the moment you find two categories here:
A) optical pick up - CD player brand and model (the reverse of that which most frequently found on the web)
B) CD player model - used LSI-ICs and some other special devices (not anywhere on the web, as I know)
From all the cd players that I had in recent years to repair, I listed here.
Unfortunately my website is only in German, therefore you can use the language tool by google for translate the complete URL. The quality of the translation is not very good, but enough - go to
http://translate.google.de/translate...hl=de&ie=UTF-8
If all members, that make service by their cd players, also listet in this forum information about the used LSI IC types in their model, in the future it would be easier in many cases, to find "hard-to find" parts as LSI-ICs and display devices of old high-quality cd player models, because they will now know some cheap models, where the same parts are inside. After buy the used model of the appropriate cd player, it can been perform the replacing and complete service by the concerning high quality cd player model
Old 21st June 2011, 03:20 PM   #2
about
Common Vintage CD players Components Composition
there are listed the whole IC setup by various cd player models.
and at follow various models also with whole IC setup, which are for service by me last time:
Sony CDP-555ESD
IC151: TA7256P (Discm)
BU-1E (Laser without model No)
IC301:CXD1125, IC302:M5128-20 OKI/MIT (FiFo)
IC201:CXA1082A, IC303: M6404A-181 (OKI)
IC304: LC6523H (made for Sony)
IC410: M5240P (Mit)
IC401: TDA1541A IC3: TC74HCU04 (TOS) 2x5532DDC (JRC) 2xNE5534P (TI) IC307: ? IC390: M54543L MIT (driver for Potentiometer-Motor) IC202/203: TA7256P Servo
Marantz 74CD42/22B (CD-42, CD42)
SAA7350GP, SAA7310GP, TDA8808T/8809T, ZC400005P, X24C16P, MIC4264P15 (DIP8) PCF2705P (SPDIF-Transmitter) SM5840P
Kenwood DP 4030 (DP4030) with Sony KSS-210A
VFD-Display: Futuba CPF2417GR and MCU uPD75216ACW-381 (uPD 75216ACW-381)
CXD2500Q (Dec, QFP)
SM5840DP ( DF, 18-pol DIL)
SM5860DP (40-pol DIL)
CXA1471S
CXA1372Q (Servo, QFP)
2x TA8410AK or LA6510 (servo power amplifier SIP)
2x TA8409S (9-pol SIP)
2 x NJM4565L (SIP-8)
4 x NJM4558D DIP-8
NAD 514 (PCB: NAD514/ISSUE 1A) with Sony KSS-210A
VFD-Display: Futuba FV467G (FV 467G FV467 G FV 467 G)
IC105: uPD75208CW-B17 (uPD75208CWB17, Bedienteilprozessor)
IC108: Technics/Matsushita MN6474AM (DAC, Mash)
IC101: CXA1081S (HF-Verst.30-pol DIL kleiner PIN-Abst.)
IC102: CXA1082BS (Servo, 48-pol DIL kleiner PIN-Abst.)
IC103: CXD1167Q (Dec, QFP 80-pol)
IC106: BA6109 (Rohm Motordriver, HSIP-10)
IC109 u. IC111: 2 x AD712JN (DIP-8)
IC110: NE5532N (DIP-8)
IC116: 74HCT00 (S/PDIF-Puffer)
IC501: NAD-CC01 C25311NF 82025 FWY W522 (Texas Instruments 28-pol DIL small pin distance)
TI, EPIC Herr Walter 0800-27583927 or 08161-80-3311 (about Freising)
Key-2-Trade EXPRESS - Global network database for electronic components.
IC107 YM3412B-F (Yamaha Digital Compressor)
NAD 5220 with optical pickup Sony KSS-152A
Additional there are mostly ICs from Toshiba in use: TMP47C420AF-8612 (MCU)
Q305: CXK5816M (SONY 8BIT Static RAM) Q306: TC9200AF Q307: TC9201AF Q303: TA8101N
Q314: TMP4270N (NU, only marking on PCB), Q513 TD6720N Q301: TA7354P Q310-313: TA8102P Q308: NJM3403ADC (JRC)
Q505: TC9154P (NU, only marking on PCB)
NAD CDRW Player C525BEE
go to post #4 about
NAD C525BEE - "No Disc" Trouble Shooting Advice wanted
check out also this threads:
Compact disc player sonic differences by various signal procesing devices before DAC
Old 26th December 2011, 11:38 AM   #3
Default More CD Player with whole IC setup, which are for service by me last time
Philips CD824/00B (CD-824) MADE IN BELGIUM
SAA7321GP, SAA7310GP, TDA8808T/8809T, ZC400005P, X24C16P, MN4264P PCF3523P (SPDIF-Transmitter)
Sony CDP-303ES
BU-1C mechanism, optical pick up without type/model number, CX20109 CX20108, CX23035 (QFP), HD4053BFP, µPD446G-20, M6404A-117 (Mitsubishi/OKI, QFP44), M6404A-41 (Mitsubishi/OKI), M50761-420P, CX23034 (dig-fil), 20152 (CX20152), MB84066B (Fujitsu)
Accuphase DP-70
BU-1C mechanism, optical pick up without type/model number, M54526P, M54583P, M54581P, CX23033, CX-20108, CX-20109, CX23035, M6404A-117 (Mitsubishi/OKI, QFP44),
D/A Converter section: 8xICL8019ACPD, 5532 (NJM 5532JRC), 2x µPC812C, 4x 4559DF, 2x 4053, 4x 74HC595, 8x 6N137 (HP), 2x 74HCU04,
S/P-DIF receiver: YM3619, 74HC14, TC4584BP
Sony CDP-XE200
KSS-213C, CXD2545Q, CXA1821M, CXD8567AM, LB1641, CXP82612-021Q
Yamaha CDX-596 (CDX596)
KSS-213C, AD1854, YSZ91-4B-F (YSZ914F-B), µPD780766F or µPD78076GF, MN35511AL, AN8785SB (Servo), AN8882SB (RF)
Blaupunkt "artech" CP-2790 (CP2790) "7 628 600"
KSS-150A, CXA1081S, CXD1135Q, CXA1082AS, STA341M (Sanken Triple Push-Pull Servo Driver) CXP5034H-069S, BX1407 (Sony IR receiver), MSM50747-677SP (M50747-677 SP), CXP5014 (Display driver), FV260G (FV 260 G, VFD), LC7881 (DAC), M5216L, M5218L (OPA, SIP outline), NJM2082S (NJM2082, JRC) LB1641 (Bidirectional Motor Driver) TC5517AP2 or CXK5816PN (CXK-5816, Static RAM)
Need cross reference for Theta Data basic II Laser disc\cd player gto127 Digital Source 16 21st October 2010 02:32 AM
Transistor Cross Reference jdkoontz Solid State 12 4th April 2010 11:20 AM
cross reference or replacement mike49504 Car Audio 1 26th November 2006 08:55 AM
Cross reference for NTE234 to other types 240z4u Parts 1 8th November 2006 03:37 AM
NTE Reverse Cross Reference beomuse Parts 0 14th October 2004 01:58 AM
Page generated in 0.10148 seconds (78.00% PHP - 22.00% MySQL) with 10 queries
