Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th August 2009, 07:41 PM   #1
Default denon 2910 dvd jitter?
Examining my denons 2910 clock setup (see atachment) puzzled me.
After the pll-chip i see an inverter, a clock dubbler, a flipflop division by two, and another inverter. After all this rubbish the output is still at max 96Khz. So in my oppinion i can rid of the first inverter and use the inverted output of the flipflop
Even better the cy2302 dubbler has beter jitter specs as the pll so i keep that in. I just don't let it dubble and use the better specs of output two and remove the first inverter and the flipflop, right?
An other question would be if the jitter spec's of the pll is at worst 450ps and the spec's of the cy2302 is 90ps wat would be the final jitter?
If the freq. is max 96k how can it play dvd-a with 192k sampling?
If i compare it with a 3910 clock setup with the same pll and cy2302 there is no division by 2.
Old 1st September 2009, 03:13 PM   #2
Default help
Clocks are not sexy anymore
Basicaly what i want to know is can i remove the first inverter and the divider and get a better jitter performance?
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
denon dv-2910 output cap Marcelinho Digital Source 5 1st January 2009 07:37 PM
location of the clock...DENON 2910 bearhughug Digital Source 5 7th August 2005 05:09 PM
Denon 2910 problem mura Digital Source 0 16th June 2005 09:30 AM
Denon 2910 - Service Manual & Pictures harbord Digital Source 0 3rd April 2005 01:15 AM
Page generated in 0.07326 seconds (67.06% PHP - 32.94% MySQL) with 11 queries
