Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th August 2009, 10:49 AM   #1
Default Marantz CC67 CD Player won't spin disk
Marantz 5 disk CD player won't spin disks. You can load it and it doesn't see the disks. Display says no disk. Any ideas?
Old 27th August 2009, 11:07 AM   #2
No ideas?
Old 27th August 2009, 11:52 AM   #3
EBM_dude's Avatar
How does it recognize a disc? Shouldn't it start turning the CD and if it can read something like the TOC it considers it a valid disc? So if it doesn't turn the disc, it never recognizes it.
I have a similar problem here with a Technics SL-PJ26A that I gotta look into. I suppose it's a mechanical fault. The first thing I'm gonny try is to look that the spindle motor isn't burned out.
Old 27th August 2009, 12:00 PM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
Does the lens perform a focus search routine and move up and down 3 or more times when the tray is closed ?
If no you might have problems.
If yes, have you cleaned the lens.
Is the turntable free.
Has it failed of it's own accord or were you working or modding it ?
What is the optical unit in these.
And after that it's proper fault finding time. Measure ALL rails and make sure no safety resistors etc are open circuit.
Old 27th August 2009, 10:15 PM   #5
Ok,
It failed on its own without help from me.
The lens moves up and down as I can hear it.
The turntable moves freely without a problem.
I changed the motor thinking it might be the problem. I had a known good
motor of the same part number.
I don't know what optical unit it has in it but will try to find out.
Old 28th August 2009, 11:16 AM   #6
The laser assy is a CDM 12.1/15
I had one in a junk unit so I used it in the cc67 player and it works now.
thanks
Old 28th August 2009, 01:05 PM   #7
EBM_dude's Avatar
So was the laser unit bad?
Old 28th August 2009, 04:45 PM   #8
Mooly's Avatar
Good to here it's fixed.
If you are feeling really brave,
Stripdown/Clean of CDM12.4
Old 29th August 2009, 12:42 PM   #9
I assume it had a problem of some sort. The motor that I put in worked when taken off the unit and having voltage applied to it. It would not work however on that particular sled. After I replaced the laser/motor sled everything worked as it should.
Old 29th August 2009, 11:32 PM   #10
EBM_dude's Avatar
Thanks. As I don't have a spare unit, I'll try cleaning the heck out of that thing. I'll report back.
FS: ADCOM 5 Disk Player GCD-700 rsk1 Swap Meet 0 11th August 2009 07:58 PM
Marantz CD46 won't spin ssjenkins Digital Source 1 13th May 2008 03:49 PM
marantz cd63 spin anti clockwise??? robertc Digital Source 12 10th November 2006 07:40 PM
Hard-disk vs cd-player hugobors Digital Source 22 31st January 2006 11:31 PM
Sony 5-disk player won't read. forethumbs Parts 8 5th October 2004 11:11 PM
Page generated in 0.09334 seconds (78.39% PHP - 21.61% MySQL) with 10 queries
