| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I actually have the Magnavox branded CDB-560. Is the equivalent Philips model the CD560? If so, are there other Philips (not Magnavox) model numbers that are close to it in design/layout? My free manuals site has plenty of Philips CD players, but not the 560, for what I'm doing, a similar model should be good enough.
#2 |
Magneto the Gravity Man
Post a photo of the inside.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#3 |
Here it is. The chip is TDA1541. The laser is CDM 2/29. Works fine except for the LED display, parts don't illuminate. Are these worth the trouble? Seen several lately quite cheap...
#4 |
This player is identical to a Philips CD560, and is part of a large family of very similar CD players. A lot of people, including myself, are fond of these players. Have a look at the Philips CD650 thread, more or less everything said there applies to this player.
#5 |
What would be some similar Philips models that I might make use of its service manual for this one?
#6 |
Ideally, get the Philips CD460/560 service manual. The manuals for the Philips CD160 and CD360 are close, these are the narrow chassis version, and are electrically the same, bar the controller/display panel. The CD650 is also similar, using the same mechanism, servo panel and decoder panel.
I have the CD360 service manual, PM me your email address and I'll send it to you. |
#7 |
I don't really need the manual just yet, wanted to see if I needed to add it to my library. Would the CD660 SM work? None of the ones you mention are listed as available, despite the fact that they seem to have about 30 different cd manuals...
#8 |
The CD660/670 is reasonably similar, but uses later revisions of the decoder and servo panels. Probably usable, but don't let the differences catch you out.
| vintage Philips loudspeakers | mounier | Multi-Way | 6 | 14th December 2009 12:36 AM |
| Speaker cabinet for vintage 12" philips driver | divingboy | Full Range | 1 | 28th December 2008 09:39 AM |
| WANTED: AD 0211/SQ4 ; AD 0163/T8 for philips MFB vintage | anton-sa | Swap Meet | 3 | 28th February 2008 03:51 PM |
| Vintage Philips Kino Speaker | tgroendahl | Full Range | 6 | 11th May 2005 09:40 AM |
| Info on vintage Peerless and Philips drivers? | Dirk | Multi-Way | 1 | 2nd December 2003 11:25 AM |
| Page generated in 0.09193 seconds (82.84% PHP - 17.16% MySQL) with 11 queries |
