Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th May 2003, 02:29 PM   #31
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
So maybe it's a good idea to remove them completely?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 8th May 2003, 02:39 PM   #32
hifi is offline hifi  Sweden
well you could but if you disconect the dac while on you will here some hevy pops when conecting it again...
/micke
Old 8th May 2003, 03:02 PM   #33
I guess one way to avoid it would be installing relays that short the output to ground when switched off and providing delay when switching on.
www.audiosector.com
Old 8th May 2003, 03:58 PM   #34
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
That would work. Or you use a large resistor 100-500 k. But you get two problems then:
- the DC of the unconnected output is not exactly zero (with 100 k the DC is quite small). Well, it is wise anyway to turn down the volume of the amp while connecting...
- you get some extra resistor noise. I think this is not a big problem
Fedde
Old 13th May 2003, 10:04 PM   #35
apassgear's Avatar
Here is a Pic of the main board before changing the PSU caps.
To the right both Jung regs for the analog section.
Old 13th May 2003, 10:24 PM   #36
apassgear's Avatar
After this long absence let me summarize what I've done to the CDP.
After changing all decoupling caps (all bypassed with small film caps) I changed all the PSU caps, taking Kuei's advice.
Al caps were "NOS" Panasonic HFS (even though I do have HFQ's) with the exception of the 6800u located before the +5V reg which was replaced by two regular ELNAs 4700u 50V for a measured 10Ku.
Other changes made were the replacement of 2 resitors at each of the I/V Opamps from Roderstain to CGW non magnetics MF.
Also I added the 3.3u caps at the MSB (Panasonic HFS). Plus some ferrite beads to the output of the Jung regs and a big split ferrite to all wires coming and going between the servo and main boards.
Old 14th May 2003, 01:35 AM   #37
apassgear's Avatar
I have logged about 8/10 hours of break-in so still not fully done plus sone 15 hours on.
My impresions so far is that is very clean sounding, deep and quite wide sundstage with lots of detail, concert music puts a huge crowd behind the performers nice bass and cleaner highs far exceeding what I have heard up to date (not much though). In relation to my Delta Sigma (DS) wins in all counts by an ample marging but two.
Dynamics and HF drama or energy.
To follow my quest and see what much is available I am preparing an Opamp I/V to replace my old stage.
The new one will be done with LM6181 (single LM6182) using a standard schem.
I have also ordered OPA660 to try Kuei's proposal.
In the other hand I'm also finishing a separate PSU (actualy 2) to feed the DAC with the three voltages needed.
Some pics of the PSU.
Old 17th July 2003, 12:43 PM   #38
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
I've just started building my TDA1543 design using Peter Daniels schematic on post #14. I am using a 33uF Blackgate N, SCR 10uF and Hovland 0.022uF for bypassing. All resistors are Vishay and both 4.7uF caps are Blackgate N types! This should be nice!
Thanks for the design - I'll let you know how it goes!
Gaz
Old 18th July 2003, 09:10 PM   #39
Rarkov's Avatar
Pics of my CD-PRO2 PSU and TDA1543 DAC / PSU are here...
http://www.diyaudio.com/forums/showt...535#post208535
Enjoy!
Gaz
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 11:10 PM
back to back isolation transformers: maxlorenz Parts 30 27th March 2006 04:15 AM
Back to Back transformers to get +B of 200V ?? Shoog Tubes / Valves 5 23rd September 2005 04:58 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 06:34 AM
Page generated in 0.14748 seconds (65.77% PHP - 34.23% MySQL) with 11 queries
