Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th May 2003, 08:07 PM   #21
Previously: Kuei Yang Wang
ThorstenL's Avatar
Koinichiwa,
Originally posted by apassgear
Peter, you sold me, I have ordered some 1543.
In the meanwhile I'll continue to play with the 1541, and then compare.
As two hints. The old Philips Player is really up for good tweaking. I would not strip out the TDA1541 circuitry.
In fact, my current DAC uses the same chipset as your CDP.
See this discussion:
Any info on DAC960 from Philips, or your experience with POOGE-5?
I'd say sort the clock out, give the DAC nice clean supply lines with good quality Cap's, check what Decoupling Cap's are on the 14 pin's for that job (I have often ceramic SMD's!).
There once was a daugtherboard mod for such machines that allowed bigger size, high quality caps to be used. The TDA1541 is EXTREMELY sensitive to PSU quality and to the quality of these Cap's. Using a modest value (3u3 is good) Os-Con or NP Black gate on the two MSB Pins gives a bass slam and attack the TDA1543 stands no chance of ever matching. Higher up in the spectrum the TDA1541 sounds cleaner and clearer than either TDA1543 or 1545.
IF the TDA1541 is well optimised the TDA1543 (also pretty well optimiesed) sounds in comparison almost crude.
But yes, getting good sound from the TDA1543 requires a minimal PCB layout, one optimised PSU and no messing with DAC "continous calibration" decoupling Cap's. Getting the best from the TDA1541 requires a lot of work, three highly critical powersupplies, fourteen highly critical decoupling Cap's, an only minimal permiassable "parasitic" voltage from the I/V conversion circuitry and so on.
Yet if you already have the TDA1541 in place I'd say you'd be MAD swapping it for a 1543 or 1545. Simply optimise the Powersupplies, decoupling, clock and analogue stage and you have something that plays with most of the things out there, regardless of price.
And remember, electrolytic capacitors of more than 4 - 6 years age are a iability, terminate with extreme prejudice.
Sayonara
Old 7th May 2003, 08:17 PM   #22
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Kuei is right, don't strip 1541 chip and don't do anything that won't allow you to go back to the original setup.
But the 1543 circuit, I propose, is so simple, that it can be added anytime, anywhere, and actually, I would be very interested in your impression on comparing those two DACs
I will also build TDA1541 DAC and see how it is.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th May 2003, 09:11 PM   #23
Nicke is offline Nicke  Sweden
Nicke's Avatar
Default Re: TDA1541A S1 come back!!!
The I/V is per Jung, if I remember this is a AD844 CF Opamp, but I'm not using a buffer so the signal goes directly from the I/V opamp stage through the output caps to the line amp.
Any suggestions???
Try Jocko´s circuit.
I replaced the analog output stage in my DAC (with AD844 as I-V converter) with a version of Jocko´s circuit .
It sounds better !
Look here:
Jocko´s simple I-V stage
Old 7th May 2003, 09:56 PM   #24
apassgear's Avatar
Kuei,
Your input is appreciated.
The 14 bit decoupling caps are what Jung recommended on the Pooge series which are 1u poliprop conformals by Panasonic and do not have any small cap addition on the MSB, but will try the best I can find for the moment (no Oscon or BG at hand).
I have ordered some OPA627 and BUF634 (unfortunately OPA660 are out of stock) to make the I/V and buffer. I know you have given quite a number of alternatives for this stage but still I'm somewhat confused to the best alternative for this small player which only drives a 50K attenuator.
So sorry for asking again to point to a suitable I/V - buffer configutation schema. and the use of CCS with J-fet.
Old 7th May 2003, 10:07 PM   #25
apassgear's Avatar
Peter,
I would be interest hearing from you on this 1541 vs 1543 shoot out.
We know we don't need to push you for those comments which are always welcomed.
Old 7th May 2003, 10:11 PM   #26
apassgear's Avatar
Nicke,
I have looked to those JH stages but for some reason I shy away from discreet for this app.
Thanks all the same for your input, I'ts always nice to hear form others experiance.
Old 7th May 2003, 11:17 PM   #27
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Originally posted by Peter Daniel
Here's the detail. The other two bypass caps are SMD, Y5U and X7R type, soldered directly to the pins underneath.
I would suggest to use 100k-200k resistors instead of the 47k drawn. And a better quality capacitor than Oscon for decoupling. Like the 100 uF BG FK (used in the Nonoz I&II). Maybe even panasonic FC would be ok there! I think that the BG would not need another smaller capacitor if the capacitor is placed very close to the DAC and regulator.
Anyone has some info for the best capacitor value for decoupling !? Kusunoki used 470 uF. Maybe for the regulators it's better to use a smaller cap ? Would 4.7 uF work !?
Fedde
Old 7th May 2003, 11:51 PM   #28
Pedja is offline Pedja  Serbia
Tony,
If you already have it, you can try AD844 in the configuration which Kuei proposed for OPA660.
Pedja
Old 8th May 2003, 12:22 AM   #29
Fedde
Actually, there was a whole thread about decoupling caps and the famous triplets. Those SMD caps are very important and the values I chosen were recommended by Pete Goudreau. Here's the exact caps: 120u Panasonic HFQ, AVX 0612 270n Z5U, AVX 0612 10n X7R.
I used 33u Nichcon as it was what I had at hand, but will use something bigger next time. Also, Ksunoki in his first DAC used 33u for decoupling at ea chip.
What is the difference when 100k-200k resistors are used at the output?
www.audiosector.com
Old 8th May 2003, 07:48 AM   #30
hifi is offline hifi  Sweden
they will put less load on the dacs output, there only purpose is to short any voltage stored in the cap to ground when the dac is not attached to anything.
/micke
Back to Back transformers and safety ground dsavitsk Tubes / Valves 1 9th February 2009 11:10 PM
back to back isolation transformers: maxlorenz Parts 30 27th March 2006 04:15 AM
Back to Back transformers to get +B of 200V ?? Shoog Tubes / Valves 5 23rd September 2005 04:58 AM
(Attn Planet 10!) active xo & 2.5 way back to back Vifa P13 mids - questions paulspencer Multi-Way 9 15th August 2004 06:34 AM
Page generated in 2.54738 seconds (6.25% PHP - 93.75% MySQL) with 11 queries
