Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st July 2009, 05:54 AM   #1
Default Philips CD880 disc clamp base
Hi, gurus. I have a Philips CD880 player that uses CDM-1 Mk2 has a worn out disc clamp base. I checked the service manual its part number is 4822 444 60467 (118 in the attached picture). I tried the disc clamp base from a CDM4 cd players and they do not fit. I'm wondering if CDM2 or CDM1's disc clamp base would fit CDM1 Mk2? Anyone has idea? Thanks in advance.
Old 21st July 2009, 06:08 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
This loader assembly was also used with the low profile CDM-2 mechanisms and their CDM-4 replacements. Players like the CD371, CD471, CD660, CD670 and many others use this same loader.
I don't have a spare disc clamp for this loader, but I've got heaps of spares for the similar later model CDM-4 loader that was used in players like the CD630, CD850 etc. I'll have a check later on and see if the two clamps are compatible (I have a CD670).
Old 21st July 2009, 06:25 AM   #3
amc184's Avatar
Just checked and no, they are not interchangeable. The later loader assembly clamp is very similar, but the subtle differences are enough that you can't swap them.
The players that I know use the same loader assembly as the CD880 are the CD371, CD471, CD640, CD660, CD670, CD771 and CD782. This list is incomplete, and of course there will be equivalent Marantz models that use it too.
Hopefully someone out there has a spare disc clamp from one of these players...
Old 21st July 2009, 06:46 AM   #4
Thanks for the tip, I also tried the loader assembly from a few CDM4/19 players CD490, CD582, CD610 and found they don't fit on CD880. From your list seems the CDM2/10, CDM4/11, CDM4/25 players would fit. CD650 probably is the most available one, but it's just amazing to see 650 still holds $60-100 resell value. eBay here I come.
Old 21st July 2009, 07:28 AM   #5
CLS is offline CLS  Taiwan
Wow! CD880! It has been 20 years, hasn't it?
I happened to own this CD players for some years. I remember there's a small steel ball at the center of the pressing disc. Later discs use magnet mostly, which I guess is a better way.
Would it be possible to convert this clamp into magnetic attraction instead of pulling force by those 2 springs?
Old 21st July 2009, 07:37 AM   #6
amc184's Avatar
No. Not all CDM-2 based players use that loader assembly. Players such as the CD150, CD160, CD350, CD360, and the CD650 use a different loader.
Stick to the players I listed before unless you know otherwise.
See the picture below to compare the two loaders:
Old 21st July 2009, 02:28 PM   #7
Many thanks for your info. From your list, seems the common pattern is CDM2 / CDM4/11 players will fit. I will search around for these players.
what can we do on PHILIPS CD880? robo Digital Source 4 26th November 2008 01:28 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips cd880 problem wising Digital Source 0 12th January 2007 07:08 PM
Philips CD880 or 960? Skorpio Digital Source 1 11th November 2006 07:57 PM
Help: EPROM of Philips CD880 LeoJar Digital Source 6 7th February 2004 04:46 PM
Page generated in 0.09330 seconds (72.86% PHP - 27.14% MySQL) with 11 queries
