Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th July 2009, 11:52 PM   #1
wwenze is offline wwenze  Singapore
Default "A standard CD player outputs signal at 24V"
Most portable devices are powered by USB and their power supply is limited to 5V. This means the output of the signal is limited to the maximum of 5V. On the other hand, a full scale component like a CD / DVD player has no such constraint, a standard CD player will happily output signal at 24V (+/-12V DC)
A standard amplifier that is designed to accept the standard 24V line input is going to struggle to deal with the 5V input. The end result is a 100W rated power amplifier struggling to produce 23W. That is why it does not sound right!
http://www.bursonaudio.com/burson_buffer_160.htm
O.o
I don't know what kind of standard those guys live with.
Old 10th July 2009, 02:30 AM   #2
Send a message via AIM to DigitalJunkie
That graph shown with the various output levels is...not right... IME.
PC soundcards generally have a level LOWER than that of an Ipod,cd player,etc.I have yet to run across a 'consumer' soundcard that outputs an actual line-level signal. They have all been about half that.
Old 10th July 2009, 04:32 PM   #3
Standard CD maximum output level is 2V RMS. Even the peak to peak equivalent voltage of that is less than 6V. Most power amplifiers are designed with a gain set to output maximum wattage with a 0.5V RMS input. "Standard' line level is generally regarded as between 0.5V to 1V RMS. I don't know where the heck they got that 24V rubbish. It can be the max peak to peak voltage output of an active stage/opamp supplied at +/-12VDC, but it absolutely is NOT any kind of standard output level for any cd, sacd or etc.
Old 11th July 2009, 04:38 AM   #4
EUVL is offline EUVL  Europe
2.4V and 0.5V is about right.
Perhaps their amp has a gain of 10 ?
P.
Old 11th July 2009, 06:08 AM   #5
cbdb is offline cbdb  Canada
That page is full of rubish, not only is the 24V thing wrong but the impedance matching is a total red herring. It only applies to power transfer, which has nothing to do with transfering a signal from preamp to power amp.
Not to mention the terrible english:
In the recent years one of the phenomenal is the raise of PC /Laptop / IPOD base audio system. The easy of use; the scalability of such system and the new loss less compression
Are you sure this isnt a joke?
Old 11th July 2009, 06:24 AM   #6
Strange that they managed to find the output impedance figures of the CDPs to put on their web, yet miss totally the output level figures which is right next to it on the specifications page.
cdbd - "Are you sure this isnt a joke?", well, it is much more scary to know that this company has long been in existence and the Burson op-amp is in fact pretty well-known, and not too long ago someone had started a thread about it: Op-Amps advice
Old 11th July 2009, 07:40 AM   #7
analog_sa's Avatar
Default Re: "A standard CD player outputs signal at 24V"
The 1000% + profit margins can skew perception a bit. The important thing is diyers love them.
Old 11th July 2009, 01:58 PM   #8
Steerpike's Avatar
They are assembling circuitry and don't yet know about DC-DC converters?
Steerpike's Toybox
Old 11th July 2009, 02:18 PM   #9
awpagan is offline awpagan  Australia
Default burson credability
burson credibility
http://www.diyaudio.com/forums/showt...185&highlight=
I still think these people make them, and Burson re-label them.
http://www.audio-gd.com/En%20audio-gd.htm
Indecision makes the world gone round.
Maybe
Old 11th July 2009, 03:02 PM   #10
scott wurcer's Avatar
Default Re: burson credability
Originally posted by awpagan
burson credibility
2012, our time is running out.
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 05:56 AM
need list of "standard" values such as impedance keantoken Everything Else 3 30th August 2006 04:40 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
A "Standard Noise Source" for SPL meters. Jonathan Bright Everything Else 6 13th July 2004 10:19 PM
"Standard" EIC power input vs. Filtered EIC Eric Everything Else 16 18th May 2001 09:31 AM
Page generated in 0.10617 seconds (81.29% PHP - 18.71% MySQL) with 10 queries
