Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
denon 3930 pll
denon 3930 pll
Old 13th September 2010, 08:50 PM   #11
esl 63 is offline esl 63
The AL24 DSP seems to run at 25MHz
Some companies is swapping the 27MHz clock
Some recommends the 24.576 MHz clock!
But if all music media sources is processed by the AL24chip DSP then maybe the 25MHz one is the one!? Sorry for my lack of knowledge, i just get confused when i get three different suggestions from people who knows...
Same block schematic as above but in two parts here, left and right side:Click the image to open in full size.
Old 13th September 2010, 11:45 PM   #12
Marcelinho is offline Marcelinho  Netherlands
I think the 24.576 MHz clock is the most important for audio. With the 27Mhz as second.
But there are a lot of chips with a lot of clocks. A professional modder did them all in the 3910.
If your good with a soldergun buy two or three xo's from tentlabs, build a low noise ps for them and feed the important chips with them. This wil cost you about 100,-/120,- euro
Old 14th September 2010, 12:17 AM   #13
I already bought a clock from Guido Tent with complete PCB.
I will mount it, install some JLH shunts, build a new I/V converter and analoge stage (ZEN I/V from Nelson Pass), and finally add capacitors to various digital chips incl the PLL supply, maybe also lowering the PLL feedback frequency to reduce jitter.
Old 14th September 2010, 09:26 AM   #14
What is feedback frequentie and how can you reduce that?
Does it have anything to do with termination?
Old 14th September 2010, 11:29 AM   #15
SoNic_real_one is offline SoNic_real_one  United States
SACD doesn't get the AL24 treatment, it goes straight to the DAC's. Clock for the DSD decoder chip is the 27 MHz via PLL in SM8707 - 33.8688MHz. That is derived from the 27MHZ XTAL via the MN2DS chip...
The 24.576MHz one looks like it is used only for communication via Denon Link (it generates RX4 signals, that is the reverse channel of the DLIII)?
Old 14th September 2010, 09:22 PM   #16
I think you are right about the dsd. Maybe there are settings in the menu that control dsd to pcm conversion if at all.
Maybe the 24.576Mhz clock is responsible for upconverting to 24bit/192Khz?, that would make it more important.
Old 14th September 2010, 11:46 PM   #17
The DSP runs at 25 MHz, it needs to execute some operations in the 192KHz datastream.
25MHz - 24,576MHz is 424kHz
Since 424 kHz is 2,208 times faster than 192 kHz music stream, could that be the spare time where every bit is executed?
Is it logical that the DSP has to run faster than the music stream?
24,576 is 192kHz*7
Itīs 7 channels in this player in total, FL FR C SW SL SR MIXL MIXR the two latest is 2 channel direct audio.
Maybee I shall hook up the scope to that PCM1796 dac tomorrow []
Old 15th September 2010, 01:33 AM   #18
The DSP is not running syncron with the datastream, it has internal RAM, software FIRs... It's like approximating the 192kHz signal with some 550-1100 intermediate samples if you want.
The 24.576MHz clock I can see that is only responsable with the RX4 channel from the DenonLink - that is the communication (for encryption of DSD and high res PCM?) from the external DAC (receiver) and also I think the external DAC can send a sync signal thru that so the PLL will lock to the outside clock.
If you don't use Denon Link it doesn't matter (I do with a Denon AVR 3805 receiver).
Old 15th September 2010, 02:03 AM   #19
Yes! RX4 comes from the FPGA and is going IN to the IC107 LC89057W-VF4A which is clocked by the 24,576MHz X-tal.
So i guess you are right! The 24.576clock is not the one to change then...
Leaving the 27 and 25 MHz clock left..
Old 15th September 2010, 02:09 AM   #20
Actually leaving the 27MHz left..
I LOVE this forum!
Thanks to everyone here babysitting the majority of us others.
Thanks!
denon 3930 pllHide this!Advertise here!
Need Help on Denon DCD-S10 Noak Digital Source 64 22nd February 2009 12:45 AM
Denon DVD-3930 Service Manual required Fidelity Audio Digital Source 0 29th August 2008 09:43 AM
Denon Pma-860 ManUtd Solid State 4 11th January 2005 09:14 PM
denon dcd 520 crippledchicken Digital Source 3 9th September 2004 06:54 PM
Denon DCD 615 Mazta Digital Source 0 27th May 2003 11:22 AM
