| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello all.
I have installed a DAC board in my Cambridge Audio D100 as a bit of fun, and to find out if the player can be improved. http://cgi.ebay.co.uk/ws/eBayISAPI.d...BSI%26otn%3D12 ![]() The D100 has a hole on the rear which states "upgradeable to digital out" but I can't find where I should take the connection for the DAC. The player had a toslink opticle out which has three wires going towards it. These come from CN1 D OUT, next to that there is CN2 DATA OUT. Please can anyone help? I can supply more photos if needed. ![]()
#2 |
hallo
you must find out the type of the pcm processor. In most cases it comes from SONY by cambridge audio. If there are CXD2500Q, please refer Pioneer PD-S 501 digital out best regards Andreas |
#3 |
The black shielded cable that goes from the mainboard to the output board will be the S/P DIF digital output. The cable will be carrying signal, ground and Vcc lines. The thicker black core will be the signal, the red core is probably Vcc and the white core is probably ground. Use a multimeter to check.
If that all checks out, connect signal to the centre pin of the RCA, and ground to the shield. Hopefully the logic levels from the mainboard will be compatible with the DAC's receiver. |
#4 |
Andreas: Thank you for your reply. The Tentlabs XO3 is a nice idea, but it is beyond the budget of this project for the time being.
amc184: Thank you for your reply. This is the info that I was hoping for. I have separated the cable that goes to the Toslink converter, and it looks like the shield was the thicker black wire, also there is a thin white wire, and a thin red wire. Which is likely to be the digital signal and ground? I have a decent mulitimeter. What should I be looking for? The red wire is +5v using the shield as ground The white wire is +2.4v using the shield as ground |
#5 |
If you're measuring 2.4 volts with a meter, that suggests the actual signal may be more like 5 volts. If so, it would be reasonable to use an attenuator or something to reduce the voltage to normal S/PDIF levels. And possibly a buffer circuit. But check the specs of the DAC; maybe it's happy with 5V digital input signals.
See this thread, which includes the schematic and pictures of the digital output I added to a laserdisc player: Mod CD/LD players with digital coaxial output - need help! |
#6 |
Yeah, thats exactly what I expected.
The white wire is S/P DIF at TTL level (varying extremely fast between 4.8V and 0V, which your meter averages to 2.4V). The optical transmitter requires a TTL level input, so as I said, this is what i expected. The RXIN input on the DIR9001 is TTL tolerant, so you can put the white (2.4V) wire to pin 20 on the DIR9001, bypassing the input stage. The red (5V) wire you can leave unconnected, that was the supply for the optical transmitter, you won't need it anymore. How the black wire (0V) is connected depends on your grounding scheme. Youcould connect it to ground on the board, but make sure that is the only connection the board has to ground. It's best to avoid a ground loop. |
#7 |
amc184: Thanks again.
I had done bit of research since my last post and had discovered that coax spdif should only be 1v, so I was worried. It is good to hear that the DIR9001 can deal with 5v. I found this cicuit that converts TTL to spdif. This was a possibility, but I thought that adding more components to the signal path could not be a great idea: ![]() Then I looked at the cuicuit diagram supplied with the dac, and thought that I could take the two TTL digital signal wires (ignoring the 5v supply) that were entering the optical output of my CDP, and wire them directly to the two wires leaving the digital reciever on my DAC (ignoring its dc supply): ![]() ![]() Or, I could just use an optical cable and retain all connections as originally designed. amc184: your solution seems the best (assuming it works) as it minimises components in the signal path. The only issue is the grounding. I will let you know how I get on tomorrow, but would also be grateful for further encouragement. |
#8 |
I am not suceeding very well here.
I connected the 2.4v (white wire) to where I thought pin 20 went to, and connected the shield to ground. Nothing. It is not simple to find where I should attach the wires. Pin 20 goes to a resistor R9. This is difficult to locate as the board is marked under the resistors. I connected it to the one at the bottom of the screen as it was the only one that obviously went to the 74HC00 chip, albeit to a different pin compared to the schematic (attached pdf). http://www.pic16.com/soft/PCM1793DAC_sch.pdf ![]() I have tempoarily given up and am using a toslink cable to make the connection. The good news is that it makes a very nice sound. |
#9 |
Hi, dublin,
You might need to disconnect the multiplexer chip (U1) from the digital receiver chip (U4) before you connect your direct TTL S/PDIF input... btw. the DIR9001 datasheet says that a toslink receiver module's TTL output can be connected directly to the RXIN pin, so there shouldn't be a problem with your signal, and it doesn't need converting (AFAIK). Also, I'm fairly certain you have the correct TTL S/PDIF signal on the D100 (it looks like the grey cable is for the analog outputs.) I'm assuming the toslink output on the D100 stops working when you unplug the small data cable? The 74HC00 chip (U1) is used as a multiplexer which lets you choose between toslink or coax input - with no toslink or coax connected, the output of U1 will be left high or low (I haven't taken the time to work out which yet, but it's probably low)... If you just leave the mux chip connected when you connect your direct signal, the low (or high) output of mux chip will "clash" with your direct TTL input. What I would do is to desolder one end of R9 (the end connected to pin 8 of U1), then solder your TTL input onto the loose end of R9. This should bypass U1 completely and connect the TTL signal to the DIR9001 (via R9, which should be fine.) If this doesn't work, then I'm not sure? OzOnE. EDIT: Just thought I'd add that if you use a TTL S/PDIF instead of optical or coax, it probably won't make a hugely noticeable improvement to the sound... The best upgrade would be to bypass the DIR9001 completely and input I2S into the DAC chip (assuming the D100 uses standard I2S). If the D100 uses a different format internally, you'll have to change the FMT pin voltages on the PCM1793 DAC. |
#10 |
Ozone makes a very good point. When I said to connect the CDP S/P DIF line to the receiver IC, I also meant that you should disconnect the existing input, as like Ozone said, they certainly will interfere with each other.
I don't think TTL to optical to TTL is a good permanent solution. With the optical connection, there is a voltage threshold where the transmitter outputs light, and a luminance threshold where the receiver outputs a voltage. If these thresholds are even slightly different from transition to transition (and they will be), phase noise (also known as jitter, I hate that name) is introduced. Phase noise is bad. Some of the phase noise from the S/P DIF input will get to the recovered clock output, no matter how good the S/P DIF receiver is. Anton |
| Progress report - digital crossover as a DAC - digital all the way to the amps | Ken L | Multi-Way | 0 | 26th November 2006 11:42 PM |
| Where can I find NPC digital filter chip "SM5843A" | aht | Digital Source | 12 | 18th March 2005 06:56 PM |
| Get digital signal from an old CD-Rom without digital output | genome | Digital Source | 5 | 3rd February 2004 11:54 PM |
| Page generated in 0.11953 seconds (89.57% PHP - 10.43% MySQL) with 11 queries |
