Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd June 2009, 05:45 AM   #1
glt is offline glt  United States
Default WDTV wish list
I Have a $99 WDTV media serve but the audio is resampled 48KHz. The video part is quite good. WD has a website where people can propose and vote for features. Here is the one for "bit-transparent audio playback":
http://wdtv.uservoice.com/pages/1744...audio-playback
www.hifiduino.wordpress.com
Old 2nd June 2009, 12:53 PM   #2
phofman is offline phofman  Czech Republic
Very likely the SMP8635LF chipset can output 48kHz only. The chipset is aimed at inexpensive DVD/BluRay playback.
Old 2nd June 2009, 02:56 PM   #3
Even if capable of Dolby/DTS/Multichannel data?
Old 2nd June 2009, 03:17 PM   #4
That has nothing to do with clock frequency of the integrated SPDIF transmitter.
Old 3rd June 2009, 02:27 PM   #5
adelias is offline adelias  Greece
Its not a limitation of the chipset. I have an Egreat EG-M34A which also uses the Sigma Designs SMP8635LF chipset.
It has no problem passing bit-perfect DTS-CD audio at 16/44.1 to my processor.
Old 3rd June 2009, 03:04 PM   #6
Thanks for the info. Thus it is just a matter of "fixing" the driver...
Old 3rd June 2009, 06:17 PM   #7
I'm curious if your Egreat can pass also 24/96 khz HD Audio through digital out to an external DAC and this DAC will lock on 96 khz.
WDTV passes the 16/44 but when it comes to pass 24/96 format it will send it downsampled to 48 khz
with the last firmware the audio clipping issue was also resolved thus now they say is outputing "bit perfect" 16/44
== NIHIL SINE DEO - Nothing Without GOD ==
Old 4th June 2009, 07:17 AM   #8
I'm fairly certain that it does pass hi-res audio since it does play files up to 24/192 but I can't confirm since the processor which I am using at moment only does up to 24/48.
Old 6th July 2009, 08:07 PM   #9
iron_gr is offline iron_gr  Greece
how can I remove the optical and put a coaxial instead?
Old 7th July 2009, 05:55 AM   #10
dangus is offline dangus  Canada
Remove the Toslink transmitter. Add a buffer (optional). I did that with a laserdisc player which had an unpopulated optical output. Mod CD/LD players with digital coaxial output - need help! There's a sketch of the layout and schematic I used, and pics of the board I made in the bathtub.
If the WDTV doesn't use 5V inside, use a chip which is 3.3 volt compliant and adjust the voltage divider appropriately. If you want a coupling transformer, I've heard you can use the little toroid transformers out of an ethernet card.
Esl To Do List bshaw147 Planars & Exotics 0 6th September 2008 05:10 PM
Not a bad list, really. leadbelly Music 22 1st July 2007 05:25 PM
my WTB list 30bandgeek Swap Meet 0 22nd November 2006 01:04 AM
DIY mic pre list tym cornell Instruments and Amps 0 10th February 2006 11:26 PM
dac list Günter H. Digital Source 1 11th September 2003 01:30 AM
Page generated in 0.09690 seconds (80.72% PHP - 19.28% MySQL) with 10 queries
