Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th May 2009, 04:00 PM   #1
farl is offline farl  United Arab Emirates
Default Please Help: CDP Primaluna P8 for repair
I have a Primaluna P8 which is not working. In the past few weeks, the problem is on and off (i mean sometimes it's working then the next day it will not).
There is no music in the analog output (both channel), it is only a hzzzzzz..... but the digital output is working fine. I tried changing the output tubes (2pcs. 12au7 and 2 pcs. 12ax7) but still the same problem.
I'd checked the voltages in all the volage regulators but they were fine.
Please help.......
Farley
Old 29th May 2009, 04:28 PM   #2
analog_sa's Avatar
Easy to locate the fault if you have at least a scope.
Old 29th May 2009, 05:19 PM   #3
that is one of my broblem, co'z i don't have a scope.
There are 4pcs. of NE5534 after the DAC. I think that this op-amps are OK because i don't think that they will get damage at one time, both channel is stop working at the same time and the supply voltage for this op-amp were fine..
Could it be the DAC?
The hzzzz.. is the same volume level in my speaker when CDP is still working. The only diffrence now is no music only the hzzzzz..
Old 12th September 2010, 07:08 PM   #4
Default pl8 problem
Hi Farl,
Did you solve your PL problem. If not, let me know. Hermanito
DIY Car Repair avatar307 The Lounge 6 22nd May 2011 10:19 PM
primaluna dialogue 5 and fanboys? lvas12 Tubes / Valves 0 1st February 2009 04:39 PM
Amp repair ddino77 Solid State 1 9th December 2007 03:50 AM
Need some help on amp repair pityocamptes Car Audio 2 2nd October 2007 07:59 PM
Help for repair my KSA 100 Alex helge Solid State 76 23rd October 2003 03:38 PM
Page generated in 0.08671 seconds (74.36% PHP - 25.64% MySQL) with 10 queries
