Hello,
If I were to use CD-ROM (such as Creative) as CD transport, can I simply use digital output at the back of the CD-ROM to connect to my DAC?
Is it comparable to a CD Player (as a transport) such as CD-63?
Is there anything to be aware of...or anything I can do to get the best out of it?
Thanks,
RR.
Thanks,
RR.
ruangrit said:
...can I simply use digital output at the back of the CD-ROM to connect to my DAC?....
I think you can't because of different signals levels - from out of the CD-ROM you get something like 5V which is far higher then normal S/PDIF signal - you must build level converter to connect to DAC.
here my CD-Rom Controller & DAC
http://hk.photos.yahoo.com/leo8597
http://jsno.arafuraconnect.com.au/proj_micro/onhold_r2.html
Refer to this URL
http://netcity6.web.hinet.net/UserData/prbetech/iNFRA/iNFRA-2.htm
Some Diyer Rebuild Creative IRFA CD-Rom
Final
Final
