Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th May 2009, 03:17 PM   #1
Skorpio is offline Skorpio  Denmark
Default PMD-100 options?
Has anyone been testing the Dither modes on the PMD-100?
It is used with PCM63P in my setup. It should be easy to implement a switch "Dither on/off" according to the datasheet?
How does dither sound, and why is it typically NOT used?
Old 11th May 2009, 02:47 AM   #2
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
I don't think you need it if you're using a 20 bit PCM63P, but if you're using the PMD100 to feed 16-bit DACs I'd probably use it.
Rigging a PMD100 to turn dither on/off should be pretty simple to do - tie the DITH pin one way with a resistor, and switch it the other way with a toggle switch or something. Then put on some music and toggle the switch back and forth and see what you prefer.
Old 11th May 2009, 07:48 AM   #3
Yes, that was my idea...to have a switch to judge by....
I just wondered why noone other had tried this?
Old 11th May 2009, 09:38 AM   #4
I have one for my TDA1541A DAC. I admit I haven't really played with it. Very quickly tried it once, and I'd say the difference is subtle.
I might go and have a play and see if I can hear anything less subtle
Old 11th May 2009, 12:13 PM   #5
While the PMD-100's dither is non-adjustable, the PMD-200 offers a choice of several dither modes from none to maximum. In addition to having different gross magnitudes, the dither modes also use different algorithms to produce their dither. We ran in the factory default of minimum dither. (The no dither mode is disrecommended for listening purposes by Pacific Microsonics.) Comparing the different available dither modes would be an interesting future experiment.
http://www.jeffchan.com/audio/filter-comparison.html
Old 11th May 2009, 12:15 PM   #6
Taken from below link:
"While the PMD-100's dither is non-adjustable, the PMD-200 offers a choice of several dither modes from none to maximum. In addition to having different gross magnitudes, the dither modes also use different algorithms to produce their dither. We ran in the factory default of minimum dither. (The no dither mode is disrecommended for listening purposes by Pacific Microsonics.) Comparing the different available dither modes would be an interesting future experiment. "
Old 11th May 2009, 06:26 PM   #7
gmarsh's Avatar
The PMD100 has adjustable dither if you run it in software mode.
Old 11th May 2009, 06:27 PM   #8
In trying to implement dither in my Rotel RCD-971, I just realized that the player har dither as standard
Pin 4 on PMD-100 is connected to 5V via 10k resistor....
So I guess I still have haven't heard PMD-100 WITHOUT dither
Old 12th May 2009, 10:09 AM   #9
Well, I tried with or without dither on mine last night (feeding dual TDA1541A) and I have to say it was immensely subtle, if noticable at all.
I think I *might* have heard a better soundstage, or more detail, but I could also be kidding myself.
Phil
Old 12th May 2009, 05:41 PM   #10
guido is offline guido  Netherlands
guido's Avatar
I'm running in sw mode and can switch between the various modes. I cannot recall that i've heard a difference too. Depends on the rest of the chain, including my ears.
But i could measure a difference.
Witout dither.
GuidoB
CCS Kit options eeyore Tubes / Valves 19 18th April 2009 04:29 PM
CD Options? renfrey Digital Source 1 5th March 2007 09:18 PM
230 V. > 110 V. -- options? on the move Everything Else 2 25th July 2005 05:01 PM
Regulation options for 807 g2 illuwatar Tubes / Valves 13 31st August 2004 05:33 PM
Any Bi-Amp options? chris ma Everything Else 3 10th May 2002 11:02 PM
Page generated in 0.11141 seconds (77.99% PHP - 22.01% MySQL) with 11 queries
