Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th May 2009, 05:46 PM   #11
guido is offline guido  Netherlands
guido's Avatar
With max dither, same settings on the 7L5.
centre of the screen is 50kHz and it's 10kHz per division.
So you see 0 to 100kHz. Peek at 0 kHz is not there in real live, comes from the SA.
Top is at -40dB and it's 10dB per division. So -40 to -120dB on the screen. But don't think this thing is calibrated after decades.....
But you can clearly see the difference: Much more noise outside the audio band, but a few dB less within the audio band.
GuidoB
Old 12th May 2009, 08:38 PM   #12
Yes, I'm sure my quiet listening conditions and other weak links meant I couldn't discern much difference - if any. I need to sort out other problems first.
Good traces, really demonstrate the effects!
Phil
Old 15th May 2009, 09:00 AM   #13
Skorpio is offline Skorpio  Denmark
When starting upgrading the player I found something interesting. The Rotel RCD-971 has a jumper for turning the dither on or off. It is located close to the PMD-100 chip.
I did not notice it before, because it is not in the schematic, there dither is permanent connected (10k to +5Vd), but in layout you can se the jumper...
So, everyone can easily test the dither influence...
As I have made a discrete I/V stage without filter, directly after the PCM63, I have disided for the non-dither, perhaps because of the increased HF noise might upset my system further down...
CCS Kit options eeyore Tubes / Valves 19 18th April 2009 04:29 PM
CD Options? renfrey Digital Source 1 5th March 2007 09:18 PM
230 V. > 110 V. -- options? on the move Everything Else 2 25th July 2005 05:01 PM
Regulation options for 807 g2 illuwatar Tubes / Valves 13 31st August 2004 05:33 PM
Any Bi-Amp options? chris ma Everything Else 3 10th May 2002 11:02 PM
Page generated in 0.08955 seconds (76.27% PHP - 23.73% MySQL) with 11 queries
