diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   24/96 question (http://www.diyaudio.com/forums/digital-source/1428-24-96-question.html)
Schaef 11th December 2001 03:22 PM
Okay, here's a simple question, I've seen information in this forum about 24 bit/96KHz capable DACs, what I want to know is, can these be used to decode a 24/96 output from a DVD player? I have at least one DVD that has 24/96 track and am curious if I use one of those DACs, could it actually decode the information and convert it to analog or is there something more that needs to be done? (I don't have a digital receiver yet, and am just curious if this could be done) Thanks for the info!
Dave 12th December 2001 01:13 AM
If you have a 24/96 track then a 24/96 DAC will decode it. But your DVD Player must have a 24/96 output. You see some DVD players down mix a 24/96 track to about 24/48 (maybe 16/48) before outputing it. Why? Well because the so called copy right protection laws invented probably by the same idiots who came up with the zone system demand this.
There are a couple of players which will output 24/96 - Pioneer Players do I think.
This reminds me - has a format for 24/192 or DSD been established yet?
johan 31st December 2001 03:54 PM
Hello there!
You where talking about a DVD. Most DVDs use Dolby Digital (AC-3) sound track, which is MPEG-1 Layer 2 compressed sound. You have no use for a DAC in that case. It outputs only noice. Ok, if you put a AC-3 decoder inbetween it should work, but stand-alone decoders are expensive. I don't know if some music-DVDs use regular pcm-sound (like CD-tracks)(?). It is not standardized. And if you play regular music-CDs there you have only 44 kHz/16 bit.
Schaef 2nd January 2002 10:17 PM
I'm well aware that most DVDs are DD or DTS, but what I am refering to are DVDs that have a 24/96 PCM track on them. In particular my wife's copy of "Into the Woods" was recorded this way, and the ELP "Brain Salad Surgery" also has a 24/96 encoded track on it as well. Its mostly a curiosity and mostly moot now, as I think I'm going to be buying a digital receiver either this month or next.
AudioFreak 3rd January 2002 01:54 AM
Just dont be certain that a digital receiver will give you 24/96 cause as Dave stated most DVD players downsample it before it leaves the player.
johan 3rd January 2002 08:50 AM
Sounds interesting. I didn't know that there where such DVDs on the market, though it is technically possible. It should also be possible to make your own 24/96 DVDs with a DVD-burner (DVD+RW is recommended). Most Philips DVD-players' (I own a Philips DVD-751) specification states 24 bit and 96 kHz. But I wonder what you see if you connect an oscilloscope. Ok, the 24 bit should work as it should, but usually the noise floor come against before you reach the theoretical limit, either in the DVD-player itself or in the rest of the audio chain. But there is no guarantee with a 96 kHz system what kind of sound there is above what you can actually hear. But to come to the conclusion, my opinion is that it should work with PCM 24/96.
Schaef 3rd January 2002 03:56 PM
In response to AudioFreak's comment about down-conversion from the player, the one that I have (Panasonic RV30) has an option to either down-convert or run bitstream out of the digital connection. So all I have to do is set it to bitstream and it'll send it on.
Johan, the 24/96 DVDs are a scarce creature indeed. The one that I have is a live broadway recording that they decided to pump the video bitrate high and use 24/96 instead of digital surround. (What's the point with a live show anyway? Who cares if the person coughing is coming from behind you or in front of you?) The other one I mentioned is a high-brid DVD-audio disc with DD tracks for standard DVD players. (In that case the 24/96 track may only be on the DVD-audio portion, but I won't know until I get the disc) I'll know more about the sound quality/difference in (hopefully) a month, after I get the new receiver.
johan 4th January 2002 12:48 PM
Hmm, remains to see yet if these old DVD-Video players understand PCM sound on a DVD, I have not tried... They maybe have to be DVD-Audio certified. I know it is possible to burn a regular audio CD but instead of PCM-tracks put Dolby Digital 5.1 tracks. The player plays it like PCM audio and it requires a DD receiver to decode the 5.1 channels. The analog output from the player just outputs noise (dangerous for amplifier/speakers). Would be fun to test a non-standard audio-CD with 24 bit/96kHz PCM stereo and see if the DVD-player likes it and if the receiver understands the PCM audio (and first if some software allows to burn such audio tracks). I have to try it some day.
Quite a jungle with these audio standards. I have to tell (it doesn't belong to this subject) about that I managed to make a standard SuperVideoCD with MPEG-2 multichannel 5.1 audio (the only way to get true multichannel audio for SVCD). But no digital receiver understands MPEG-2 encoded audio (quite funny because MPEG-2 was the audio format first specified for DVD-Video although Dolby Digital and DTS won the battle), though DVD-players usually are able to decode the MPEG audio tracks and put them out from the analog 5.1 output on the player.
Schaef 4th January 2002 03:21 PM
I thought mpeg-2 audio was supposed to be the DVD audio standard in Europe? (I take it from your comments, its not) As to the PCM thing, the "Into the Woods" DVD is a full video DVD where they recorded the audio tracks at 24/96 for playback, so the player understands that. (Its the only audio track on the disc in English if I remember correctly)
On a side note, how would you get 24/96 data playback on a standard CD to work? The throughput isn't high enough without some form of compression. (I know about the DTS CDs, I haven't seen a DD CD yet)
As to belonging to this subject, I think we've wandered away from the original question already... (Not that I mind, its still quite interesting!)
johan 4th January 2002 04:10 PM
I don't know all of the history about DVD, but the fact is that in Europe it is almost only DD (AC-3) DVDs today (a few with DTS). Almost every DVD-player has support for MPEG because of VCD and SVCD compatibility (VCD uses MPEG-1 layer 2 and SVCD may use MPEG-1 stereo, MPEG-2 stereo or multichannel and one or two language tracks).
Another interesting thing is that the European digital cable television standard has MPEG-2 audio. For now at least in Finland they are using only MPEG-2 stereo sound, but they are investigating in using Dolby Digital 5.1. I know also that German and the biggest company in USA has decided to use the same digital cable standard as in Finland. There are lot of work changing to DD, so why they don't use MPEG-2 multichannel? Maybe because of that digital receivers don't support MPEG-2 multichannel.
Ok, I know that IF 24/96 audio works on a CD (absolutely not in any ordinary CD-player) there is room for only about 22 min. of audio (on a 74 min. CD) (see this thread: http://www.diyaudio.com/forums/showt...p?threadid=123 )
Dolby Digital and DTS CDs should work in exactly the same way.
Copyright 1999-2017 diyAudio
