MicroSD Memory Card Transport Project - Page 59 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th March 2013, 11:17 PM   #581
Bunpei is offline Bunpei  Japan
What a nice idea and a wonderful soldering skill for using an U FL connector!
By the way, Acko designed an adaptor board for U FL connectors though it is not distributed yet.
ackoDAC based on ES9018
Old 11th March 2013, 11:47 PM   #582
Yes! :-D
Old 12th March 2013, 11:27 AM   #583
Default Remote Control
I am VERY interested in a remote control kit! The Apple remote control is an ideal partner
Meanwhile, would you care to show your remote control setup (ohoto)?
/S
Hi, SDTrans384 users and those who are interested in a SDTrans384 board kit!
Tachyon is considering a possible distribution of optional remote control unit for SDTrans.
Bunpei and some other users in Japan developed their own remote control receiver by using an Arduino micro-controller board, Apple IR remote and modified Hifi-duino code.
I hope you enjoy music with SDTrans!
Old 12th March 2013, 11:31 AM   #584
Try the Salas regulator. There are groupb buys going on on this forum.
Or try the Twisted Pear super shunt regulator.
Originally Posted by bikerboy View Post
Any schematics for a really good regulator I can solder?
Thank you again for the great SD player.
Old 12th March 2013, 02:04 PM   #585
I use a simplified version of the Salas regulator fom my SD Trans.
Here you can find the PCB:
FS: PCB's and opamps
This is high current version but you can modify the ccs current changing the resistor.
Ciao
Guglielmo
Old 13th March 2013, 09:07 AM   #586
compressit's Avatar
guglielmope, did you use normal wire at first for MCLK before using the U FL / coax? Was there an audible difference between that and what you have now?
Asking because I have a much further distance between the SD and my dac than I should.
Never ending quest to get the noise out
Old 16th March 2013, 06:45 AM   #587
Meanwhile, would you care to show your remote control setup (ohoto)? ...
I'm ssory that I can't show any pictures as of now because I had sold my units to my friend and I have none at my hand now.
I will post a picture of new one in the near future.
Bunpei
Old 20th March 2013, 09:50 PM   #588
Hi Bunpei,
I received the pps caps and installed them last night. Need to let them burn in for a couple of days. They are different looking compared to other caps I have used. Thanks Bunpei
Old 23rd March 2013, 08:14 AM   #589
Default PPS caps
Once again a small change and wow. PPS caps are needed. Now its more intimate and real. But then my I2s goes bad so I'm using the Bnc output. 3 days of continous burnin makes for sweet sounds.Even the Bnc sounds great.
Old 23rd March 2013, 08:56 AM   #590
Very interesting!
Where did you install the PPS caps? On SDtrans384? What value(s).
Do you have a photo?
What happened to the I2S?
/S
Usb Memory Stick/flash Card sdman Digital Line Level 5 5th September 2009 01:37 PM
FS: AMD 1 GHz CPU, motherboard, 256MB RAM, video card, power supply, network card Jimmy154 Swap Meet 0 14th June 2006 08:15 PM
My CD-Transport project YENFU Digital Source 17 24th September 2005 05:27 PM
Copyright 1999-2017 diyAudio
