MicroSD Memory Card Transport Project MicroSD Memory Card Transport Project - Page 51 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd July 2012, 12:51 AM   #501
davewantsmoore is offline davewantsmoore  Australia
Originally Posted by elecon View Post
Well, I just wanted to congratulate with a truly excellent project worthy of praise on the excellent site DIYaudio.com.
Cheers
Seconded. These are really nice guys, doing excellent work.
Old 14th July 2012, 11:29 AM   #502
hirezfiles is offline hirezfiles
Originally Posted by Bunpei View Post
I am quite addicted in listening DSD256 sources these days.
DSD256 sources can be prepared in the following procedures.
Converting to a higher sampling rate do not add any information about the original signal. Could you please explain what is so special about these converted files?
Old 14th July 2012, 02:00 PM   #503
Bunpei is offline Bunpei  Japan
Hi, hirezfiles,
I think your question is very reasonable.
First, I want to explain my background.
I'm a computer system engineer. Therefore, I have some basic knowledge on information theory.
I have listened such PCM high resolution sources as DXD 352.8 kHz/24 bit or 192 kHz/24 bit.
ESS ES9018 is the only DAC chip I use for playing DSD256 sources so far.
(A Japanese DIY USB-DDC board designer says TI DSD1794A is also capable for playing DSD256.)
My observation is "Sources converted to DSD256 sound far better than original 44.1kHz/16bit PCM in general". Many audiophiles around me those who actually listened to the sounds agree with this opinion.
I have never experienced such any positive effect of upsampling before in the case of conversion from 44.1kHz/16bit PCM to 352kHz/24bit PCM.
However, in the case of DSD256 on ES9018, the effect is remarkable.
I'm not sure whether this is common to other DAC chips or not because I have never tried any DAC chips other than ES9018 as of now. One possible explanation might be that this is an unique finding to the ES9018 chip.
The quality of resulting sounds apparently depends on methods or programs involved in a conversion process from PCM 44.1kHz/16bit to DSD256.
(Within my experiences, "DSD Direct" program released by SONY gives the best DSD256 sources.)
My current interpretations are;
1. Usual 44.1kHz/16bit PCM sources inherently contain far richer information than that we expected before. However, many of conventional DAC have failed to exploit it.
2. DSD256 is accidentally the most suitable input data format for ES9018 DAC chip.
3. The conversion program might add some additional information.
(According to a blog article found in a Japanese web site, SONY DSD Direct uses FIR of 30,000 taps in its initial upsampling process.)
I hope my explanation can be a suitable answer for you.
Bunpei
Old 15th July 2012, 01:12 PM   #504
matthiasw is offline matthiasw  Germany
Default DSD DAC
Bunpei,
it would be very much appreciated if you gave us some informations about your new exciting project:
The new USB based ASIO 2.2 compatible DSD DAC as a DIY audio kit.
Kind regards
matthias
Old 20th July 2012, 06:09 AM   #505
ihear21khz is offline ihear21khz  Malaysia
Bunpei,
I fitted the capacitors you referred to in post 299 as instructed. They do make a major difference to the sound quality of the already very good sounding SDtrans.
The background is much quieter, micro dynamics are better reproduced and the bass definition improves. It is just more real and transparent.
Those who have heard my system are amazed how much closer to life my system sounds - even with just 16bit 44.1khz material.
Hi rez piano recordings are even more realistic and get many people who walk along the street looking into my home to try and "see" who is playing the piano. I tell some of them "no piano, only hifi" and they are surprised.
Your SDtrans is now my main reference transport. You guys should make a larger production run. I am sure if I show off the player to others that share this hobby, a fair few would pay for the privilege of owning it.
Cheers
David
Old 20th July 2012, 07:26 PM   #506
Greg Stewart is offline Greg Stewart  United States
-SNIP-
I still find this very interesting. This is adding bypass caps to an already well-supplied and regulated digital transport's digital processing chips!
BUT, when I did similar bypassing to my computer transport's Juli@ sound card's digital section, which supplies an I2S feed to a separate DAC, I got similar results. I did this partly after being inspired by the comments in post 299.
Thanks to Bunpei & Chiaki for not only making what may be one of the best digital sources available today, but also for advancing the digital transport state-of-the-art with their tweaks to their transport.
Greg in Mississippi
P.S. And I can heartily endorse a larger production run!
Everything matters!
Old 22nd July 2012, 12:53 AM   #507
thoglette is offline thoglette  Australia
thoglette's Avatar
It's basic electronics that building an effective cut off filter for 20K signals from a 44.1K DAC is the devil's own task.
Old 4th August 2012, 10:39 AM   #508
Dear Matthiasw,
I'm very sorry to such a delayed reply.
You might have read my post on J River Media Center BBS.
To our regret, the project has been suspended actually. Chiaki became very busy for preparing a new ES9018-based Dual Mono DAC board with 90/98 MHz oscillators. (The board includes no I/V stage.)
As I was not satisfied with any existing USB-I2S/DSD boards, I had asked him to make a preliminary design of his own USB interface board. However, he found it is not so easy.
Best regards,
Bunpei
Old 4th August 2012, 10:55 AM   #509
Dear ihear21khz and Greg,
Thank you very much for your reports.
Chiaki had designed his SDTrans384 revision 3 board (originally it was referred as "SDTrans192") very carefully assigning a low noise voltage regulator for each power line. In spite of his effort, it has been proved that his original design was not the best because not a few users including me added their own favorite bypass caps or connected their own power supplies to the board and obtained their own better sounds.
I'd like to recommend SDTrans384 users add your best bypass caps or connect your best power supplies to your board. You efforts will be surely rewarded.
However, please be careful enough not to mis-connect a high voltage. Some users have broken their board because of high voltage power supplies.
Bunpei
Old 4th August 2012, 11:17 AM   #510
Dear thoglette,
Yes, you are correct when we think of frequency components stored in CD. An anti-aliasing filter applied before CD mastering cuts completely signals above 20 KHz.
However, I used the term "richer information" that covers wider meaning than "frequency components". For example, how about "a phase reproduction" or "a time-domain wave form reproduction", etc.?
I hope you can listen to DSD256 sources converted from CD sources actually and then build your theory.
Best regards,
Bunpei
MicroSD Memory Card Transport ProjectHide this!Advertise here!
Usb Memory Stick/flash Card sdman Digital Line Level 5 5th September 2009 01:37 PM
FS: AMD 1 GHz CPU, motherboard, 256MB RAM, video card, power supply, network card Jimmy154 Swap Meet 0 14th June 2006 08:15 PM
My CD-Transport project YENFU Digital Source 17 24th September 2005 05:27 PM
Copyright ©1999-2017 diyAudio
