Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
MicroSD Memory Card Transport Project
Old 7th February 2010, 12:50 AM   #101
Bunpei is offline Bunpei  Japan
Originally Posted by giolight View Post
Would be nice to have detail for the external clock multiplier and comparator circuit and which are the modification at the transport in order to accept the external clock?
I will ask Mr. Ishida whether he can disclose his circuit or not.
Regarding his modification, I heard that he removed a resister at an output of TCXO and extended wires to his sub board.
Bunpei
Old 7th February 2010, 01:41 AM   #102
Default Mini Review by SR
SR, One of our users in Europe, gave me his mini review report with his permission to post it here by his private e-mail.
Bunpei
Mini Review by SR, February 2010
Conclusion
The SDTrans192 player won me over for its superb sonics and extraordinary high rez capabilities. It is so darn good that the $450 price tag is fully justified.
Build quality and functionality are outstanding, operation is flawles, and service is very good.
Compared to the $115 memory card player QA550 from QLS Hifi Audio,
the SDTrans192 beats it hands down. And that is using SPDIF from the SDTrans192 and I2S output from the QA-550.
Old 7th February 2010, 01:46 AM   #103
Default Mini Review by SR (Detailed Test Description)
The Japanese guys Bunpei and Chiaki have been working on their memory card player since April 2009. Going from prototype version 1.0 to the now available version 2.1 which is a totally other beast than the more simple version 1.0.
Sidebar: do have a look at Chiakis immaculate wiring on his prototype board here MicroSD Memory Card Transport Project
Version 2.1, which I have tested the last week, can play WAV files up to 24/352.8 kHz. Not many players - not even commercial ones - can boast with being able to play these DXD files. An amazing achievement! I had no isses playing and listening to files up to 24/192 - I cannot listen to DXD files.
The player can be used with SD cards in sizes 2 - 32 GB (FAT and FAT32)
and I had no issues what so ever with my mix of different SD and SD/HC cards in
sizes 2, 4, 8, 16, and 32 GB from a variety of manufacturers. They all worked fine.
The player can interface to DACs via transformer-coupled SPDIF or via I2S.
There is also the possibility to
hook up an I2C interface, but I did not test I2C, nor did I use the I2S interface. I plan to test the I2S interface later on, and compare sonics against the external HiFace USB->SPDIF converter which can convert up to 24/192.
They call it a kit but what it actually takes to get it playing is
a 5V power supply. Then you are ready for music.
The 16-char X 2-lines display deserves some extra words. It is gorgeous! So bright and so sharp. A medium blue background with white letters. A small pot lets you can change the brightness level. The display shows what song nr is being played, what bit depth and sampling frequency the WAV file has, and a blinking arrow shows that the player is playing music.
Five green LEDs let you know that all the different power supplies on the board are fully operational. Two other LEDs show if the SD card is accessed and if the I2S output buffer is empty.
Four soft buttons control the player. I really like the feel of these buttons.
There are the standard play, rew, and fwd
buttons, and a fourth mode button lets you change music files folder.
For this review, I used a linear 5V power supply and my own SPDIF 75 Ohm cable with Furutech rhodiumised BNC and RCA connectors. The DAC that I used was the PCM1792A evaluation board. This board has been totally modifed on the analog side with TX2352 resistors and polyprop film caps for decoupling and filtering. IV conversion on the eval board is made with
LT1468 OPamps. The eval board is powered from four linear regulated power supplies.
I used the HD650 headphones throughout the test. My own discrete dual mono headphone amplifiers fed the head phones.
The 4 GB SD card that comes with the SDTrans192 is packed with high rez music
- all the up to DXD resolutions - from 2L. A neat feature of the kit. For my sonical evaluation, however, I used my own music with whom I am familiarised.
Listening to my well-known, EAC-ripped music, this player can really "sing"!
Bass is firm and detailed down to the lowest octave, mids are natural, and the treble is silky smooth. Resolution is top notch. Soundstage is very wide.
Comparing the SDTrans192 (via SPDIF) to a car battery-powered QA-550 (via I2S) and having each player use a 2 GB sound card with the exact same WAV files, I can, on for ex "Tiden bara gaar" (OPUS3 Records), hear that the triangle really sounds like a triangle, and the congo drums are more sculptured out than on the QA-550, and the bass line is easier to follow on the SDTrans192.
Now, the QA-550 has been my main digital source the last year. For $115 it is bargain! Still, its treble representation is not on par with the one from the SDTrans192. That I can hear on for ex Dire Strait's "Love Over Gold" song where both the hi-hat and the reverberation of the snare drum are more silky smooth on the SDTrans192. On the QA-550 these sounds are almost harsh.
On Sly Stone's reggae-influenced song "Moanin'" (Telarc) the sound opens up with the SDTrans192. It becomes wider. The reverb tones from the SDTrans are a bit more easy to hear, and in general, sonics are "cleaner" with less harshness with the SDTrans192.
Female voices get a more present and full presentation on the SDTrans192 which I hear on "Black crow". The drums on "Drummer's reel" are faster with less ringing on the SDTRans192. Transients are not harder but less smeared out.
Like the QA-550, the SDTrans192 makes my feet tap to the music :-)
The SDTrans192 player is now my main digital source.
What could one more wish for in the SDTrans192?
Well, I for one would like to be able to see on the
display what song is being played. I have forwared this request to the designers, and let's hope that they will implement it.
Old 21st February 2010, 03:12 PM   #104
jkeny is offline jkeny  Ireland
Banned
Does SR want to sell his QA-550? I'm looking for one, cheap! Can you put me in touch with him or pass on this request?
Old 4th March 2010, 05:58 PM   #105
lga775 is offline lga775  Malaysia
Yesterday, at elecon's site at Tokyo, I listened Mr. Ishida's SDTrans192 with Rubidium-based external clocking units.
The effect was especially and easily detectable on 352.8 kHz / 24 bit 2L DXD sources. I think its sound is the most perfect and accurate among digital sounds that I ever listened though my experiences are limited.
I felt every single tone was maintained as non-degradated. I was astonished that even a faint diminishing sound of strings and piano held its fine structures.
Mr. Ishida prepared his clocking systems after his vigorous efforts.
However, costs for materials are not so expensive at all.
He selected Rubidium Oscillator FE-5680A that was easily available at eBay.
1 Hz to 20 MHz|Programable Rubidium Frequency standard - eBay (item 290301888238 end time Feb-03-10 05:56:05 PST)
As SDTrans192 requires two master clocks, 22.5792 MHz & 24.576 MHz, he prepared two units.
(If you send appropriate commands to the unit by way of a serial control line, you can change its output frequency easily. This time, he prepares two units of pre-set.)
FE-5680A's frequency limit is 20 MHz and its output wave shape is sine-only. Mr. Ishida made a multiplier with sine->square shaping using Phase Link PLL502-02 and a comparator.
http://www.phaselink.com/pdffiles/PLL502-02.PDF
Therefore, two FE-5680A were set for 11.2896 MHz and 12.288 MHz, respectively.
The multiplier & comparator unit is shown on a sub-board appearing to the right side of SDTrans192. He also tweaked SDTrans192 clocking circuits in order to accept external clocks.
I'd like to express my gratitude to Mr. Ishida and "elecon" who offered his excellent audio room and equipment for listening tests.
can i know how to make the clock into square wave, and the design of the circuit where the 11.2896mhz clock enters the clock multiplier IC?
i read after the ic specsheet, it says only accept 12mhz and above up to 50mhz?
Old 6th March 2010, 04:41 AM   #106
Mr. Ishida sent me his schematic and asked me posting here.
He hopes it is helpful.
Old 7th March 2010, 06:37 PM   #107
can i know what are those IC? i know only 74AC163 and PLL IC others i don know.
can you help more? what are those other chips? where can i source it?
Old 9th March 2010, 01:14 PM   #108
can i know what are those IC? i know only 74AC163 and PLL IC others i don know. can you help more? what are those other chips? where can i source it?
A line-receiver IC is SN75157 and counters are 74AC163 and 74HC163.
I think these are available on Digi-Key web site.
Bunpei
Old 9th March 2010, 02:03 PM   #109
what counters are 74AC163 and 74HC163 for? what are those 176.4khz,88.2khz and 44.1khz for?
Old 10th March 2010, 04:48 AM   #110
lukedodd is offline lukedodd  Australia
Default purchase kit
I have joined this thread recently. I would like to purchase the kit, can someone help with the necessary link. Thankyou
MicroSD Memory Card Transport ProjectHide this!Advertise here!
Usb Memory Stick/flash Card sdman Digital Line Level 5 5th September 2009 01:37 PM
FS: AMD 1 GHz CPU, motherboard, 256MB RAM, video card, power supply, network card Jimmy154 Swap Meet 0 14th June 2006 08:15 PM
My CD-Transport project YENFU Digital Source 17 24th September 2005 05:27 PM
