| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Dear Friends.
I need a VAU1254 CD-PRO2LF module ( got my one broken experimenting a recloking circuit). No way to get reply from www.diy-high-end.com. Could someone give me some advice about a different supplier in Europe?. Thank you. agalavotti |
#2 |
Ciao
...maybe you damaged the SAA7324. It's the main IC of the board, you can remove it cutting and desoldering the pins one by one. Philips sell it spare through their service net. If you need the service code of the SAA7324 I can give it to you. |
#3 |
Hi Roberto.
Thank you for your reply & offert. Unfortunately I don't think the problem lies here. I had a problem with a switch and the CD pro remained for some seconds without clock. The optical group started moving from one side to the other like crazy, then stopped forever. Bye agalavotti |
#4 |
Some time ago I switched on the cdpro with the ext. clock disconnected, the pick-up moved like crazy but nothing bad happened...
Are you sure that the cdpro is completely died? Don't you see any movement of the pickup? No TOC reading? In my experience when the cdpro seems died it's often a connector in a wrong position. Are the TDA7073 ok? they're the balanced drivers of the mechanical actuators, you should find around half supply voltage on the output pins. I've some service manuals of Philips products which use the CD10 chipset. It's the same chipset of the cdpro, the surrounding circuitry differs a little but these manuals could help you to find the problem. If you are interested give me a (large) mail address. |
#5 |
I can help you, just PM me.
#6 |
Hello
I also have troubles with my CD-PRO2, it does not read the TOC. First, it does not play Hybrid SACD, then I cleaned the lens and now it not read any CD format. Someone can help me? |
#7 |
I got problem with CD-pro too. After modding, (give a +5v supply to pickup to FPC directly), pickup movement is normal without disc. But when I put the disc on, the disc is rotated in opposite direction and TOC can't be read. Please help. |
#8 | |
In Europe, you can now get CD-Pro2LF modules from AudioCDPro. I think they are located in France. |
#9 | |
You can check the focus function with the service commands of the CD-Pro module. |
| supply regularly CD-Pro2 module VAU1254 CD-Pro (VAU1252) CD-Pro2 (VAU1254/11) vam1250 | smartech | Vendor's Bazaar | 1 | 10th April 2011 10:02 AM |
| Vhere Buy Cd-pro2lf | GIPIONE | Digital Source | 5 | 12th July 2009 10:08 PM |
| Supplier of laser head and assembly in Europe | gacpar | Digital Source | 1 | 9th March 2009 12:15 AM |
| amveco (or equivalent) transformer supplier in europe | iampivot | Vendor's Bazaar | 0 | 27th May 2007 03:49 AM |
| Fountek Ribbons Group Buy (Europe, but maybe not only Europe?) | Carondimonio | Group Buys | 34 | 24th October 2004 08:10 PM |
| Page generated in 0.09070 seconds (80.32% PHP - 19.68% MySQL) with 10 queries |
