| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have been getting a few Japanese re-mastered albums that are done in 20 and 24bit.
I was wondering if standard CD players can output that resolution though their digital outputs to a stand alone DAC to be converted. Or would they only read it at 16bits, essentially down-converting it before outputting it though its digital out? If that is the case, would a DVD Audio player be needed to read these re-mastered albums at their full 20 and 24 bit resolution? |
#2 |
Hi lotuss79,
you have to convert your files to 44,1 KHz and 16 Bit if you wnt to play them on a normal CD Player. If your player is able to playback DVD-Audio you can use for example a DVD authoring program like Cirlinca's Solo to write yor 24 Bit files on a DVD. But I think your Player will only use the internal DAC to output a analog signal and for copyright reasons you will not get the digital high resolution stream on your SPDIF. But there are solutions for this handicap. One example is here: Hirez SACD and DVD-A digital output for Pioneer DV-575A and DV-578A (dsd to pcm) |
#3 |
Thanks Tranceformer,
Maybe i will try going through a hard disk drive/music server. That might be the simplest way to output 24bit audio to my DAC. |
#4 |
Yes, I think thats the way to go. Do you want to build your own player or do you plan to buy a hard disk player?
Not all "Mediaplayer's" are able to play 24/96 audio. Even when they play the files some units do an internal conversion to 16Bit before they stream it to SPDIF, and I am sure this is not what you want. |
#5 |
Thats a good point. I would have liked to go with iTunes, but i dont believe they support 24bit. Ill have to look into that.
#6 |
All 24-bit remaster means is that when they EQed and whatever else to the file, they did it at 24-bit. Then they convert the mastered files to 16-bit with dither for the CD. A regular CD player will do just fine.
#7 |
Thats disappointing, but thanks for the clarification.
#8 |
The only way to get the equivalent of 20 bit resolution on a regular CD it is HDCD. In Asia, the format it is more popular than in the rest of the world.
#9 |
Eh I still think it's 16-bits.
If you want to get that 20-bit trick try ripping regular CDs with Exact Audio Copy, converting them to 24-bit and then running them through an expander like Waves C4 (UNCompressor preset -13dB). Imho s process like this which is done at 48-bit or 64-bit floating point DSP will usually beat out any HDCD player. |
#10 |
standard 75ohm coax cable can not transfer 24bits digital audio - you will have to use balanced 110ohm professional link.
Boky |
| Subwoofer not outputting | bubbers214 | Car Audio | 4 | 5th March 2006 10:56 AM |
| Fancy a +100KHz, 24bit digital scope for £99/$150 | annex666 | Digital Source | 10 | 17th October 2005 12:09 PM |
| trafo outputting higher than rated Vdc | timsch75 | Solid State | 9 | 1st November 2004 08:11 PM |
| SPDIF outputting device. | Akh_Ind | Digital Source | 3 | 14th March 2004 09:48 AM |
| Page generated in 0.11575 seconds (83.72% PHP - 16.28% MySQL) with 10 queries |
