Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
CDB 650 with TDA1541A S1 not working
Old 22nd April 2003, 04:29 AM   #1
apassgear is offline apassgear  Mexico
apassgear's Avatar
Default CDB 650 with TDA1541A S1 not working
Well after all the noise with TDA1541A vs S1 I decided to test my old CDB650 but does not start.
The problem seems to be with the front control panel.
Turning on the player the platter spins for a moment and I got voltages on the main PCB. There is a power supply to the front panel of 24 V, that one also works but the display does not light up and the control buttons are dead.
I have the full Service manual for the CDP but I'm not very familiar with these type of digital control so I'm asking for help.
Most likely is a simple problem since the last time I used it was running OK.
Any suggestion where to start
Old 22nd April 2003, 04:41 AM   #2
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
sounds like a ribbon cable going to the panel from the main board
Old 22nd April 2003, 11:32 AM   #3
guido is offline guido  Netherlands
guido's Avatar
I had something similar with mine, during playing it:
stopped playing
display went dead
tray comes out
With mine it was a problem with the 24V connector making bad contact. Just bend the cabling a, must be due to taking the thing apart.
GuidoB
GuidoB
Old 22nd April 2003, 12:54 PM   #4
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Unhappy Solid Core cables easily break off
These "Klingeldraht" [beatiful German for doorbell-cable] cables easily break of. Most of the time just in the connector. You can take apart the connector and refit the broken cable. It is not easy and it is a totally hopeless construction. Shame on you Philips. With older cables it might still not work as the connector has tiny knives that have to cut through the isolation of the cable. This may be difficult as the plastic becomes hard over time due to evaporation of the softener in the plastic...
Been there done that
Old 22nd April 2003, 04:25 PM   #5
apassgear's Avatar
Thanks for the input to all you guys
I'll check those silly cables connectig all those boards. Well they have survive up to this point all my mods. I have disasembled the CDP maybe 50 times!!! during all this years. Funny but it always worked the first time after each of my ruthless changes. This shows the other side of the coin.
Will be back as soon as I check the spagetti plate
Old 22nd April 2003, 04:53 PM   #6
carlosfm is offline carlosfm  Portugal
Banned
Tony,
24 volts seams a low voltage to those display types, but I don't know those cd-players inside.
Normally it's anywhere between 30 and 40 volts.
Maby someone that has a CD650 can help you.
Check from where the voltage comes, and it may be a bad zener near a voltage regulator.
I've been there, with a Marantz.
Old 22nd April 2003, 05:01 PM   #7
Jocko Homo is offline Jocko Homo  United States
Banned
As I recall, the CDB-460/560/650 vintage did have problems with the IDC connectors.
As Elso pointed out, you can carefully disassemble the connector, and it back in working order. It might be easier to use a new connector, but finding a new one that size may be tough for the average DIYer.
I believe that had an LED readout, so there will probably not be anything higher voltage on it. The later models did use fluorescent displays.
Jocko
Old 22nd April 2003, 05:30 PM   #8
Banned
Default Display supply in Philips CD-650
Hi ,
I own a Philips CD650!
The display supply is on the most right side PCB. AC comes from the transformer and is rectified on this board and regulated with a 78M24CT to +32V. (pin2 is connected through a 8V2 zener to ground to get 32 V). From there it goes to the control + display circuit.
The cable may seem OK as only the core is broken and the plastic isolation still intact. I usually pull at each lead to verify its condition....
Old 22nd April 2003, 05:54 PM   #9
Banned
Talking Yes, the zener!
Yes Elso, it may be that 8v2 zener the problem of Tony's cd player.
After all, he has voltage on the display circuit, so it may not be the cable!
The 24 volts he has is exactly the regulator voltage, without the zener.
And it affects the microprocessor also, so that the commands don't work, not only the display.
Believe me, I've been there.
Old 22nd April 2003, 07:04 PM   #10
apassgear's Avatar
Well some more info.
Yes, what I initialy check was the voltage at the regulator, 24V.
I tested the cables from the 32V PSU and found that the red #3 pos (grd) came loose but I'm not sure there wasn't a connection before I pulled it.
Next I tested for voltage without the connector in place, at the pins, and I got 32V across #3 and #4 pins.
After reconnecting the red wire I checked that I had continuity from the end of the wire to the metal stripping female connector. reistalled but nothing again.
next I stripped part of the insulation from #3 and 4 wires to see what happened with the circuit connected. I got only 2.4V and double checked it.
Thinking I could have a short some place I observed the voltage during the shut down of the CDP but the voltage came down not very quickly at the said points.
Suggestions please???
CDB 650 with TDA1541A S1 not workingHide this!Advertise here!
WTB Krell KSA Mk2- working or non working Jozua Swap Meet 0 20th March 2006 12:14 PM
TDA1541A etc old man Digital Source 0 5th September 2005 11:59 PM
