Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
NAD C541i laser tracking problem
Old 16th March 2009, 10:29 PM   #1
supernet is offline supernet  Europe
supernet's Avatar
Default NAD C541i laser tracking problem
Hello!
My NAD C541i player has great troubles to recognize the discs in a tray and number of songs. After some investigation, I replaced the laser (KSS 213D), clean all mechanism and put little teflon oil on steel pipe on which laser travels up and down. After reinstalation of the laser, CD player normally quick recognize the CDs and start playing...but quite funny...I can normally choose the songs from 1 to end, but if I want to go reverse (from song nr. 8 to 2), the laser move down and then start to loop cycling to find the track. Sometimes it find one sometimes not. Only way to go from nr.8 to nr.2 is to press stop button between, so laser can return to starting point.
What do you think could be wrong?
thx
Old 18th March 2009, 11:37 AM   #2
Mooly's Avatar
These are classic symptoms of an alignment issue, assuming there are no major mechanical issues.
The first step is too examine the quality of the RF or "eye pattern" on an oscilloscope, and to see what electrical adjustments are provided for. Focus bias and EF balance are the two most critical--- if adjustment is possible. If this is marginal then all kinds of problems occur.
Old 19th March 2009, 12:57 AM   #3
supernet's Avatar
Thanks.
I will try to borrow oscilloscope during weekend and check eye pattern.
Do you know maybe, where it is possible to find test track to test this?
Old 19th March 2009, 07:07 AM   #4
Mooly's Avatar
Any commercial CD is fine... you don't need a test disc. Try a few just to make sure you don't pick a particularly poor one ( low reflectivity ) The eye pattern will always look the same no matter what the disc contains.
NAD C541i laser tracking problemHide this!Advertise here!
problem with old Sony PS-LX510 linear-tracking turntable -- mechanical question Pickngrin Analogue Source 21 15th February 2015 08:53 PM
Kenwood KDC-M9021SE laser unit problem lostsoul_msh Car Audio 0 2nd April 2009 06:31 PM
NAD C541i problem androll Digital Source 1 2nd July 2007 05:37 PM
Tracking problem, need help Assyst1606 Digital Source 21 19th October 2006 11:13 AM
denon dcd 1500 II tracking problem iapx8088 Digital Source 1 8th September 2004 11:33 AM
Copyright ©1999-2017 diyAudio
