Lossless SD-card player - Page 68 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd May 2013, 06:37 PM   #671
marce is offline marce  United Kingdom
Looks cool, and nice to see something other than the standard box.:0
Old 2nd May 2013, 06:42 PM   #672
Hi jean-paul,
BTW John, are those RCA/cinch sockets in the ISDV1 not too close to the transformers ?
The ISDV1-player is experimental.
The sockets on the rear were intended for AUX input and when they are connected I use screening tubes that fully screen the RCA socket pin and attached interlink.
Connections between SDV1-player and power amp modules are hard-wired and don't come even close to the transformers.
The final products are separate units as can be seen on my new website. Two separate monoblocks and a separate SDV1-player.
The SDV1-player is always powered by an external 12V DC power supply, even for the experimental ISDV1-player.
Old 22nd September 2013, 03:39 PM   #673
maxlorenz's Avatar
Hi -EC-
A couple of questions:
You declared you are using another DAC chip for improved sound...did the output circuit (I/V) also changed?
With my present SD card reader I have troubles with random playing of orderly tracks: is your SD1 free of these troubles?
Thanks.
M.
SP: QLS launched an SD player that has opamps at the output, and I am (you have me) accustomed to passive or discrete JFET outputs...
Old 22nd September 2013, 04:20 PM   #674
Onnosr is offline Onnosr  Netherlands
Hi EC
What type of DAC chip you are using now ??
Onno
Old 29th October 2013, 10:02 AM   #675
Hi maxlorenz,
The DAC chip was changed in order to realise lowest possible DAC chip jitter contribution in combination with active jitter control.
The I/V circuit consists of a 250MHz current buffer (meets DAC chip output compliance) that drives a variable, passive I/V resistor.
Output is DC-coupled in order to maintain transparent sound.
The SDV1-player supports both, disc and track shuffle these work fine.
Old 29th October 2013, 10:53 AM   #676
Hi onno,
I am using a selected multibit DAC chip in the final SDV1-player.
Old 29th October 2013, 11:17 AM   #677
maxlorenz's Avatar
Originally Posted by -ecdesigns- View Post
Hi maxlorenz,
Thank you very much for your reply, dear -EC-.
So no opamps...
About the tracks, I didn't explained well my trouble: my reader disorders orderly tracks without reason.
M.
Copyright 1999-2017 diyAudio
