| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#21 |
SD-card player prototype is working, there are some minor problems with SD-card latency, this will be solved by doubling RAM buffer size.
SD-card access is software-driven, I2S signals are generated by the on-chip DCI module and through DMA. The player already supports multiple directories (99) and multiple tracks within each directory (99 track / directory). Long file names can be used as well. Shuffle play (CD / tracks) also works. Bit clock jitter can be kept very low as expected. First impressions of sound quality are very good. The SD-card latency limits max. sample rate and bit depth. The latency is basically caused by the on-card controller, and may vary with SD-card brand. |
#22 |
Very nice. Any photos?
#23 | |
John Congrats to you (and brothrer!) Onno |
#24 |
How about user interface (display, remote, ....) ?
And when would you be offering to us ? I have a serious interest in the frontend part, up to I2S output. There are just too many limitations in the Koonlab version. Pls keep us posted. Patrick |
#25 |
Just came across this...
http://www.compactstick.com/ it seems the only stuff being released in this format at the moment is psychedelic trance, however it will be interesting to see if this becomes more widely adopted. There is specification for the filesystem layout here: http://www.compactstick.com/cs_contents_v10.pdf |
#26 |
Could a Squeexebox be used to output I2S?
If so, it will handle FLAC no problem? Whilst the media os not solid state, has no mechanical and servo parts which I think is the point of this thread?? Ian
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
#27 |
ecdesigns, are you planning an electronic control (user) interface of some kind? This would make it a very useful module for other projects.
There are a ton of cheap transflash and sd players (also mp4 video) from china around for between $20 - $35. Do you think any of these would be hackable for i2s or some kind of digital output? |
#28 |
ecdesigns,
It would be very useful to buffer both the clock signals going to the dac and dsp, as changes in the impedances or pll pulling (if that happens in the internal circuitry) will cause some jitter. It will be a pity to loose the clean clock to this. Also, make sure all impedances are matched as far as you can from chip pin to external circuitry. Looking forward to the final thing! |
#29 |
Hi git,
The prototype is built around a Microchip DV164027 MPLAB debugger module: http://nl.farnell.com/microchip/dv16...questid=734245 We added a SD-card holder, an external 2.8224 MHz low jitter clock, and a stereo DAC for testing. The microcontroller is a DSPIC33FJ128GP802. I try to make and post some photographs of the test set-up soon. |
#30 |
John,
I hope you would offer a dedicated board before long. I like your designs, not only this one but also your TDA154x DACs, especially the linear interpolation. Innovative stuff, as one often finds in designs coming from the Netherlands. ![]() Patrick |
| Page generated in 0.11128 seconds (72.96% PHP - 27.04% MySQL) with 11 queries |
