| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Most interesting.
There is at least the TEAC WAP2200, etc. on the market which can read FLAC, WAV, MP3, ..... and other formats from a USB stick or USN HDD, and for a bargain price of 120 Euros, but it only ruins it all with an SPDIF output (probably the only optional for a commercial product), so you get the problem back with different clocks for the Source and the DAC. I2S out and DAC from the same clock is probably the best solution. Can we then use your linear interpolation idea as well and drive the Sabre 8 channel, effectively getting 18 bit, 192kHz ? Patrick |
#12 | |
Hi gene klein,
We are not using a FPGA, it's a DSPIC33 series micro controller with dedicated on-chip hardware for SPI / I2S. It's a 28-pin chip (no SMD). The intention is to support WAV only, FLAC decoding could be included as well, but creates too high interference levels (larger processor load). We are attempting to create a self-sustained DMA-controlled data flow, meaning that the controller is basically idling during playback, and will produce minimum interference. The main objective is to achieve best possible performance, not adding unnecessary features that would complicate things and would possibly degrade performance. The SD-cards can be quickly re-written many times, so I don't see the need for using lossless compression like FLAC. Cheap SD-cards can already store 2Gb of data, that's already enough to store 4 CDs in WAV format. The latest cards have a capacity of up to 64Gb, and it's likely this capacity will be further increased. The 64Gb card will already be able to hold the maximum amount of 99 WAV CD images. It's also not practical to have so many CD images stored on a SD-card that's used in a basic player like this (browsing). The WAV files are stored on the SD-card using a computer. This can be done by creating a sub directory for each CD, and simply copy the WAV files and CD cover-art in this directory, that's all. We also plan to provide software that extracts data from iTunes for example, and writes it on the SD-card using correct directory and file names. Next the SD-card is placed in the stand-alone player that will then work without computer. We were thinking of the following approach for storing files: Each CD image is placed in a separate sub-directory. The sub-directory name must start with a two-digit number, followed by artist name and CD name. The WAV files (tracks) of that specific CD are placed in that sub directory, again using a two-digit number, followed by the track name. The CD cover art is also placed in this directory, I always use 500 x 500 pixels and a file size of approx. 40Kb. This way, all required data (Artist name, CD name, track names, and artwork) is present on the SD-card. The computer can extract all data from the SD-card, and display the card contents, cover-art included. This information can be printed for reference. The data on the SD-card can be backed-up, read and written by any computer, without conversion. The basic SD-card player will scan the SD-card upon insertion, and knows how many CDs and tracks are stored on the card. This information is then used to quickly display, and access the selected CD / track. The SD-card player will only scan for directories / files that start with a two-digit number. The SD-card player will (have to) use FAT32 for supporting higher SD-card capacities, and because of the integrated SD-card controller properties. We use an existing FAT32 library, offered by Microchip. Each SD-card will also receive a unique number that will identify it (when multiple SD-cards are used to store a CD collection). The SD-card player displays this number upon insertion. Depending on SD-card capacity, a play-list can be generated to play-back a maximum of 99 stored CDs images, or the equivalent amount of mixed tracks. The player will be able to shuffle between stored CDs, tracks, or CDs and tracks. The DSPIC micro controller will run on a very low jitter master clock. This master clock is located close to the DAC chip, and directly drives this DAC chip. Both DATA and WS will be generated by the DSPIC. This is possible because both devices run in sync, the DAC master clock basically slaves the controller. Finally we plan to include a (slow speed) optical communications channel for extra functions like remote control, and retrieving information from the inserted SD-card. |
#13 |
Hi ecdesigns,
I was actually asking the question to cbroegger Sorry for any missunderstanding Gene |
#14 |
Hi John EC
Are you interested in de schematics of the Edirol R1. It has a clock running on 11.2896 and i2s intern feeding a DAC. Easily diy for output i2s. I am using now a 744T from Sounddevices (coax spdif) and I try to get schematics to get i2s out of it. Onno |
#15 |
Hello -ecdesigns-, I was actually looking for something like you propose, but all I could find were dual players for mp3 aimed at the DJ-market. Your project makes a lot of sense, and I actually wonder why such a unit is not (yet) available on the market.
While music servers are one way to digitally store and play your music collection, they have several disadvantages: They are noisy and need to to be placed away in a room where the noise does'nt matter, they need a transmission to the stereo rig in the living room (cable or wireless), and if the worst happens, all your music is lost in a disc crash. If continuously run, such a server also consumes quite a bit of electricity over the year. Your product would be able to store quite a bit of music on a single card. The cards are getting larger capacity and cheaper each year, which makes for a very attractive and future proof design. If a card is lost or damaged, only a fraction of your music is lost (and of course you could store backup cards to avoid this). No moving parts, no noise. Just a player that would replace your cd-player, but would be much more convenient. The clocking/jitter problem can be solved in a really elegant way. Couple this with an excellent ADC, and you have the potential to get really outstanding SQ. And imagine that you could store quite a number of chips in one CD sized box instead of having a whole bookshelf full of CD's. Since you probably would only occasionally change cards in the player, the player box could be in a cabinet, out of sight; most women would love this. Mavbe you could even allow for 4 card slots instead of one, which would allow for higher active storage capacity. I also could imagine that some audio companies would be quite interested to talk with you, once you have a working unit. Just wanted to encourage you. |
#16 |
#17 |
Hi Guys,
Putting aside the convenience. Would the play back quality be as good as a good quality CDP ? The concept by EC in itself is super but what about the corruption that might be added during the transfer of data to the SD card ? |
#18 |
ecdesigns,
Very nice!. I know you have a commercial interest, but have you thought of building a basic arduino shield with an sdcard reader and a dspic chip and some basic library to select a file and get the DMA going?. There is currently an "arduino wave shield" but very limited since it is using PIO |
#19 | ||
Hi JC951t / git,
Unlike CD players, it's insensitive to shock / vibration, and jitter induced by the opto-mechanical servo system is also eliminated. Read errors don't occur, because the original CD can be ripped using programs like Exact Audio Copy. This SD-card reader was basically the result of reaching a dead-end, using conventional digital audio sources (jitter, interface / interlink issues, and data integrity problems). Quote:
#20 | |
