| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 | |
[QUOTE]Originally posted by fmak
[B] Quote:
Did you (or others) by any chance measure the output noise of that circuit ? best regards |
#42 | |
Yes, in situ in SACD player with supply from 12V regulator; I can get down to about 60 uV with OSCons across LM431, input, and output. I think some of the noise is coming thru' the 7812; really needs separate ps. The player I put this in has a very noisy digital section and power supply. Guido, have you processed my order yet? Please send an email. Fred |
#43 | |
What is the measurement bandwidth of your instrument ? If it is "infinite", 60 uV is not that bad ...... I will ship tomorrow, I visit he postoffice once a week otherwise It will cot me too much time (people queuing all the time) best regards |
#44 | |
Bye the way: What is the regulator noise when not in the circuit ? |
#45 |
Hi Fred
Bye the way: What is the regulator noise when not in the circuit ? [/B][/QUOTE] -------------------------------------------------------------- Guido Not in circuit, around 30 uV. Bandwidth 1MHz, Trio ac voltmeter, unweighted. |
#46 | |
Guido Not in circuit, around 30 uV. Bandwidth 1MHz, Trio ac voltmeter, unweighted. [/B][/QUOTE] Hi Fred Calculation done in my head: That is about 30nV/Sqrrt Hz, not bad ! regards |
#47 | |
Calculation done in my head: That is about 30nV/Sqrrt Hz, not bad ! ----------------------------------------------------------- Guido This took quite a lot of effort; not just connecting up ps to a regulator, and adjustments of decoupling in situ. Silencing the SACD player (Sony SCDXB940) took much greater effort. I have never seen so many inductors built into the design which unfortunately have multiple grounds and long cable runs to the ps. Fred |
#48 |
Hii Guido Tent or .
Hola como estas. Wiich is your opimion in these Graphics; Jesús
JPJ |
#49 | |
Estoy bien (I am fine) Just looked at the graphs. The PLL seems to put out a sine wave, which has more jitter as the input, so I would not use it. What is the measurement time ? Any info on the spectral content of the distributed noise at the PLL output ? best regards |
#50 | |
Hi all
What is the best way to achieve this? 1. Does one provide separate regulated supplies from the original transformer, for each servo? OR 2. Does one use a separate transformer for the servo section? OR 3. Does one use a separate transformer and power supplies for the sensitive stuff (DAC, analogue stage....) and leave the servos to be powered by the original transformer - with separated supplies? OR Something else?????? Regards Fin |
| Sealed box dimensions influence | IG81 | Full Range | 6 | 7th April 2009 08:08 PM |
| beta influence | maxpou | Solid State | 2 | 27th August 2007 11:38 AM |
| Electromagnetic Influence | fmak | Digital Source | 0 | 9th January 2004 09:24 PM |
| What is the influence of your listening room? | massive | Multi-Way | 15 | 12th January 2003 03:25 AM |
| Page generated in 0.12483 seconds (84.13% PHP - 15.87% MySQL) with 11 queries |
