Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 12th February 2009, 02:08 AM   #1
Default How to connect diyparadise i/v stage to tda1541A
Hi......I have completed a tda1541a nos dac kit ( analogmetric )....all voltages have been checked and are spot on.I am not using any op-amps after the dac , but instead the diy paradise i/v stage, which I believe is optimised for the tda 1543 dac ?.
I am using a squeeze box 3 as source.When I turn on the dac ....I just get hiss and no music....as I turn the gain up the hiss goes up, but still no music. One funny thing I have noticed as that when i change stations on the sb3 it goes dead quiet, then when it locks on the new station....hiss again!.
The outputs from the dac seem ok, as I temporarily connected one 50 ohm to gnd and one 50 in series before a 20uf blocking cap at the output rca connector. I got music in both channels, altho low in volume.
thanks
" I love cats....but I couldn't eat a full one. "
Old 12th February 2009, 08:34 AM   #2
Katapum is offline Katapum  Europe
You I´ll have to build an output stage:
Passive -> TDA – I/V resistor – output stage or active -> TDA - diyparadise i/v stage
Old 12th February 2009, 12:53 PM   #3
ccschua is offline ccschua  Malaysia
U have to connect pin 13 of CS8412 to ground. And then bend the pin 9 of 74HCT4040 ( so that it does not sit inside the socket).
try listen again.
Old 12th February 2009, 02:09 PM   #4
jonners is offline jonners  United Kingdom
jonners's Avatar
I believe the diyparadise I/V is this one: http://www.diyaudio.com/forums/showt...018#post323018
Unfortunately you can't use it because the TDA1541A needs to see 0V DC at its output.
An alternative would be this: Simple I/V for TDA1541
Hope this helps.
John
Old 12th February 2009, 06:31 PM   #5
Default Thanks guys
...thanks for all the suggestions.... I will work out the most suitable and report back.....I didn't realise the tda1541a was so "fussy" about what it drives....this is a steep learning curve for me.
Paul
Anybody know how to connect the DIR9001 with a TDA1541A in a non-os dac ? gaetan8888 Digital Line Level 22 6th March 2011 09:28 PM
Another I/V stage for TDA1541A Sandor Digital Source 1 6th December 2006 07:09 AM
MISSION PCMII analogue stage board connect? Chayaphat Digital Source 0 8th November 2005 11:13 AM
Amplifier design: how to connect a stage with the next one? Bricolo Solid State 8 27th February 2005 07:05 PM
how to connect the TDA1541A to the DF1706 ?? weissi Digital Source 13 12th June 2003 09:53 PM
Page generated in 0.08455 seconds (78.11% PHP - 21.89% MySQL) with 10 queries
