Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th February 2009, 02:10 PM   #1
Default Conrad Johnson DV2b skips
Dear digital experts,
this is the first post of my life, so sorry for my inexperience...
I have an old (1995) CJ DV-2b integrated cd player, which skips bits. I discovered that it use the Philips CD720 (Maranz CD46) brown board with a CDM 12.1, replaced with a VAM1202 + L1210/11 combo. The DAC is SAA7345GP + TDA 1545A.
Since two years the player started to skip bits.
I have already replaced the VAM 1202 (made in China) with a Philips VAM1201 (made in Japan) but apparently the problem reappeared after a few days. You can see details of the work here:
http://digilander.libero.it/agostino...b_vam1202.html
I also put oil for the ax.
I don't know if the problem is in the VAM1202, or in the tray loader (which level is not perfect for both the clamp bridge and the VAM mechanic), or in the board chips/parts.
Any help to fix this problem is welcome.
Last, I would like to know from experts if there are suggested mods for the digital part (the output stage is already good, I guess) or if it is possible to replace the whole Philips mechanic and brown board with something better (but using the power supplies and output stage already present).
Thank you in advance!
Old 9th February 2009, 03:56 PM   #2
If possible I add also a picture of the Philips board, where you can see (where the flat cable is soldered) where they took the -digital I think- output signal. Hope that this could help in suggesting mods/replacements...
Old 12th February 2009, 08:16 AM   #3
I don't know if that this could help to solve my mistracking problem, but, for the sake of completeness, I add a picture of the Philips board from bottom, where you can see that the TDA1545A has been desoldered. You can see just the SAA7345GP and the TDA1301T servo processor (maybe it a source of reading error?).
Outside of the Philips board, in the CJ board, there is the clock circuit and the TDA1305T DAC, which is still a bitstream, but much better than the SAA7345GP. I think that CJ bypassed the 7345, perhaps using I2s? I think that the DAC/output stage of this cd player is really good, I would like only to upgrade the drive mechanic and servo circuits...
Thanks for looking,
Tino
Old 17th April 2009, 07:14 AM   #4
Hi digital world,
I have finally solved this problem buying a used Philips CD720 and using its CD12.1 mechanic to replace both the original tray loader and my new VAM1202 mechanic. After one month of tests, it still works perfectly.
I tried the new VAM1202 on the old Philips CD720 and it skips a lot of data. I still don't know if all the VAM1202 which I bought on eBay were faulty or if the Philipd CD720 board (CJ DV-2b) are not fully compatible with the VAM1202 mechanic...
I have posted more details in my audio web site:
Ciao!
Help! Schematic Conrad Johnson MF 200 zyhauw Solid State 0 18th March 2009 11:49 PM
FS: Conrad Johnson Premier 11A amp Studley Swap Meet 0 18th January 2007 10:50 PM
Conrad Johnson PV 7 problem Peppe Tubes / Valves 8 8th November 2006 08:37 AM
Conrad Johnson MV 45 schematic help 845 Tubes / Valves 1 21st December 2005 04:39 PM
conrad johnson help efoda Tubes / Valves 3 24th January 2002 03:23 AM
Page generated in 0.09318 seconds (78.25% PHP - 21.75% MySQL) with 11 queries
