Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd February 2009, 07:34 PM   #1
sendler is offline sendler  United States
Default Tried to piggyback two AK4395 dac chips
I tried to piggyback a couple AK4395 dac chips last night but the legs are a little too short to reach down from one chip to the other. They are very small and hard to work with. It's too easy for the chips to get really hot while trying to solder them. Looks like paralleling dac chips will have to be left to those with boards that are designed for it. Might not help much without having separate output resistors for each chip's output to prevent one chip from current hogging anyway. I'll have to see if I can come up with a way to make a header onto a new circuit board in order to try it.
Scott
Old 4th February 2009, 06:59 PM   #2
thru-holes, one chip at the top, the other at the PCB bottom Other electrical transitions from one side on to another should be done as close to pins as possible with (if posible) 2 thru-holes per transition.
Boky
AK4395, AK4396 dac chips for sale sendler Swap Meet 1 23rd August 2009 05:24 AM
piggyback transformers milen007 Parts 6 9th March 2009 05:18 AM
AK4395 dac xaudiox Vendor's Bazaar 0 22nd November 2008 12:37 PM
Little Piggyback Capacitors CarlosT Chip Amps 9 4th December 2006 03:16 PM
AD1865 in piggyback cmt42001 Digital Source 6 10th November 2005 09:30 PM
Page generated in 0.06640 seconds (69.33% PHP - 30.67% MySQL) with 10 queries
