Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st February 2009, 06:55 PM   #1
spgjmf is offline spgjmf  United States
Default gainn stage for tda1543 dddac fet?
hi folks,
I have built doede's easy usb dac with the 2707 and tda1543 dac chips. The output of the 1543 is too low for my whee little amp, 6em7 SE...the 2707 drive ut fine, but the 154 needs more output.
I would like a gain stage which could use the 12vdc supply as the kit already uses....maybe somethig using fets, ( i have some 2sk170) . op amps are ok too, just they need dual supply or Vert grd.
I trired the simple opa2604 stage as suggested in the app sheet, but only got a tinny am radio sound...no bass. anyway any suggestion or cicuits to bring the 1543 output up to a higher level would be great. like I said simpel fet preamp would be great.
btw - the dac kit is an easy build and the 2707 sounds darn good too, great detail. now if I can only hear NOS dac...
thanks for any suggestions,
Jeff
Old 1st February 2009, 07:17 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you can implement this one , or Papa's Jfet BOZ , whatever ;
looking at pic - just toss input pot , and place cap on output .
for values for 2SK170 - search for Papa's Jfet BOZ .....
cap multiplier is pretty important here , even if used one is most generic .
it will work , better or even better on pretty much every voltage from 12 to 30 V
in case that you're looking for more advanced circ ...... just say so
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 2nd February 2009, 03:30 AM   #3
Thank Zen Mod.
I like the jfetBox so much I built one this afternoon.
I added a 0.47uf cap on the src to add a little brightness. oh, and the src res. is 10 ohm.
I realy like it, it matches well wit the tda1543 dac. Gota love the nelson PAss stuff....oh and I think I am hearing the macic of NOS dac. new stuff appearing in different songs.
thanks again - it was very enjoyable to get working and build -
thats what DIY is for. so now I have usb dac to jfetBoz to 6em7 amp driving fe103 speakers. simple diy which sounds great to me.
lm1875 next ...
here is a pic of the build.
best,
Jeff
Old 7th February 2009, 10:17 PM   #4
just wanted to follow up.
I built a jfet BOZ and have put this and the dddac1543 in a small case. I added a volume pot between the dac and the boz. The output of the pcm2707 is too hot and needs taming when running thru the boz.
I really like the simple boz and intend to build a few more. The 5143 is really nice, laybacked and not aggressive. the 2707 on the other hand is very dynamic and fast(?). both have their places in the listening world.
here a pic of the set up. still need to finish it up, but at least the clip leads are gone.
best,
JEff
Built the DDDAC MKII USB audio card, modified it to feed SRPP tube amp line stage wa2ise Tubes / Valves 0 8th June 2008 03:21 AM
Planning to modify a DDDAC USB TDA1543 DAC board with tube outputs wa2ise Digital Source 1 13th May 2008 05:00 PM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 08:34 PM
My experimental I/V stage for TDA1543 Bricolo Digital Source 12 16th April 2004 03:01 PM
TDA1543 from dddac.de/ma_dac21.htm bsyyu Digital Source 46 26th October 2003 01:48 PM
Page generated in 0.09207 seconds (70.81% PHP - 29.19% MySQL) with 11 queries
