Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd March 2005, 02:11 AM   #121
pooge is offline pooge  United States
Hmm. Twelve pages of gossip and no mention of commercially available recommendations for TRUE 75 ohm BNCs. It was mentioned that some were sold as 75 ohm, but are not true 75 ohm. It's just that they mate to 75 ohm cable. The contruction between 75 and 50 is clear, but it's often hard to see in the brochures and catalogs to verify.
I'm looking for a true 75 ohm female panel mount. Any good commercially available recommendations?
Also, looking to use 75 ohm coax between jack and coax. Is solder connection to jack better than BNC female on the inside of the panel?
Old 22nd March 2005, 02:21 AM   #122
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
I just designed an AMP 413194-2 BNC connector into something.
Outer shell isn't gold, but the center pin is.
Old 22nd March 2005, 03:57 AM   #123
Don't care about the gold. Just looking for proper impedance and good quality. Also, something easy to chassis punch. Don't have any double-D punches.
Old 22nd March 2005, 04:03 AM   #124
Mikett is offline Mikett  Canada
My old Assemblage DAC 2 sports a 75 ohm BNC, I think it's vampire.
Old 22nd March 2005, 04:10 AM   #125
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Digi Key A24602 is 75 ohm chassis mount connector: http://dkc3.digikey.com/PDF/T051/0262.pdf
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 22nd March 2005, 09:01 AM   #126
Send a message via MSN to Mark Hathaway
Howdy guys,
no one has mentioned, www.neutrik.com have a full range of 75 ohm and 110ohm products.
Jocko and Guido, did you measure standard xlr connectors or Neutrik's XCC 110ohm series?
Mark
Old 22nd March 2005, 10:45 AM   #127
Is anyone familiar with TRUE 75 ohm bulkhead jacks that are easy to mount in a chassis so they won't turn? The recessed ones look like they only need a round hole punched. I see in the Markertek catalog that they have Canare, Neutrik, and Switchcraft versions of these. I'd rather not go the recessed route, but would if it was the best solution. I know some of the bulkhead jacks need double-D holes, so they are out, since I don't intend to purchase such a punch for only a few jacks. Are there any bulkhead jacks that use a simple round hole that have a good arrangement to prevent the jack from turning in the hole? It's really hard to find some of these details, even from manufacture website data. If not, the recessed jacks look like the answer.
Old 26th March 2005, 02:14 AM   #128
FWIW, Trompeter makes a gold flashed 75-ohm BNC with gold plated center pin in their video broadcast line, said to have the lowest return loss in the industry
http://www.trompeter.com/shop/downloadcat.asp
Old 26th March 2005, 07:10 AM   #129
Just get the Canare BNC heads from Markertek. They are true 75ohm and can do GHz. They are simply the best, gold plated or not. Many very high end DACs such as Zanden use them. You can also get the plastic washers which will improve the turning problem a little.
-finney
Old 26th March 2005, 05:25 PM   #130
You are likely speaking of the jacks here. The Canares are certainly good enough for DAC use, since DACs use relatively low frequencies. I'm leaning to the recessed ones, because they use simpler round holes. But they take up a lot of room if trying to modify an already crowded panel.
As to plugs, the Trompeter look to be a better choice for HDTV frequencies and video cable use. These are also available at Markertek.
Direct Gold plated PCB reMC Digital Source 0 9th April 2008 03:32 PM
FS gold plated mission 774 arm tube AudioOrigami Swap Meet 0 7th March 2005 07:12 AM
Why does cheap brass plated hardware corrode so much? leadbelly The Lounge 1 26th August 2004 03:44 PM
Gold plated jacks to... johnferrier Everything Else 1 21st December 2003 05:09 AM
Page generated in 0.10345 seconds (76.81% PHP - 23.19% MySQL) with 11 queries
