Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th April 2003, 04:40 PM   #1
tone's Avatar
Send a message via ICQ to tone
Default dac only works on cdrom !! why>? pls help!
hi all,
have been running my diy dac on cdrom for quite sometime now..
the dac wont work on cdplayer digital output..
what's wrong??
pls help..
thanks.
CS8414 receiver & tda1541a nos dac.
tone.
Old 13th April 2003, 05:33 PM   #2
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb DAC receiver
Hi Tone ,
Did you put the CS8414 in the right mode= 2 (see table 3 in the datasheet)?
Check also for all three digital signals entering the DAC: WS, BCK and DATA. DATA is difficult to recognise on the scope but you must see "activity".
Good luck,
Old 13th April 2003, 09:11 PM   #3
vuki is offline vuki  Croatia
vuki's Avatar
I would say it's something with SPDIF input circuitry. What are you using at input; transformer, active drive (buffer) or is input connected directly to receiver?
Because: CDrom has TTL level output (5V) while CD player's SPDIF output should be (and often is) 0,5V.
If you are using some kind of active circuit or transformer with wrong prim/sec ratio there could be a problem with input level.
Old 14th April 2003, 03:50 AM   #4
omar is offline omar  United States
Default Re: DAC receiver
Originally posted by Elso Kwak
Hi Tone ,
Good luck,
Hi Elso Kwak ,
My 8412 is working under mode 5,
any different between mode 2 and 5?
Old 14th April 2003, 07:49 AM   #5
Banned
Lightbulb Re: Re: DAC receiver Modes
Originally posted by omar
Hi Elso Kwak ,
Hi Omar,
Mode 2 is for I2S outputformat used by TDA1541A, TDA1543
Mode 5 is 16 bits out LSBJ for TDA1545A, AD1851, PCM56
Mode 6 is 18 bits out LSBJ for AD1865.
All DAC's mentioned used NON-OS.
What DAC are you using Omar?
Old 14th April 2003, 08:59 AM   #6
Default Re: Re: Re: DAC receiver Modes
Hi Omar,
Hi Elso Kwak
The next stage of my 8412 is digital filter, sm5842,
then goes to PCM1702.(It's a DIY DAC )
So I don't know if I could choose either one?
Any improvement to the sound quality?
Thanks!
Old 14th April 2003, 09:52 AM   #7
Banned
Lightbulb Mode Settings
Hi Omar,
Tone is using a NON-Oversampling DAC. That is NO digtal filter is used!
If you digital filter works with mode 5 everything should be OK.
See also the datasheet of the SM8542.
Old 14th April 2003, 09:56 AM   #8
Default Re: Mode Settings
Hi Omar,
I got it~
Thanks!
Old 14th April 2003, 08:28 PM   #9
tone's Avatar
Default dac
hi elso, the dac is in mode 2
as for the input circuitry: 0.1uf-pulse transformer ratio 1:1-75R to grd.
vuki: yes cdrom has TTL spdif output 5V..do i need to convert to anything else as for cdplayer digital output?
thanks
tone.
Old 14th April 2003, 09:52 PM   #10
vuki's Avatar
Hi tone,
why don't you try it without input transformer? Then you'll know what next. If it works without xformer I suggest you to make active drive for receiver (a differential one with 74HCU04 and 74HC86) and forget the xformer.
CDROM vs transport Leolabs Digital Source 29 16th June 2011 03:20 PM
Any one know this DVD/CDROM KIT ? ECBLN Digital Source 0 17th May 2008 08:05 PM
CDROM controller muka Swap Meet 17 11th January 2006 09:12 PM
Cdrom hum pete.a Digital Source 3 23rd March 2005 04:15 PM
Anyone knows NEC CDROM? omar Digital Source 2 8th January 2004 08:45 PM
Page generated in 0.12325 seconds (79.39% PHP - 20.61% MySQL) with 10 queries
