Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 11th May 2003, 07:00 PM   #131
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Dupply for CS8412 PLL
Originally posted by Guido Tent
dear all,
You seem to like CS8412 a lot (I use it too). From all the published circuits I see, I have 2 suggestions:
- Decouple filt pin with 10 nF to ground ? Crystal IC designers put it next to MCK pin, they "slightly" lack of understanding of RF crosstalk.....(in average 1 pF is present between 2 pins)
- Redesign the loop filter in order to decrease incomming jitter ?
enjoy,
Hi, Use low noise analog supply for the loopfilter section of the CS8412:
http://db.audioasylum.com/cgi/m.pl?f...12&r=&session=
Orginal post by Wildmonkeysects in this thread:
Old 13th May 2003, 07:17 PM   #132
PTSOUNDLAB's Avatar
Default Good Low Noise PSU
Hello,
does somebody have a schematic or a link for a good very low noise simple PSU (250V without choke if possible) for the Thunderstone analogue stage for TDA1543 I have put in my "NONOZII DAC Output Stage" post ?
Thank you boys.
Pascal.
Old 13th May 2003, 08:11 PM   #133
Banned
Smile Re: Good Low Noise PSU
Originally posted by PTSOUNDLAB
Hello,
Thank you boys.
Pascal.
Hi Pascal,
I am sure Thorsten (K.Y.W.) has some fine schematics with choke filtered supplies for tubes. I am sorry as I am not into tubes. Can not give you advice here.
Did you check his website and forum?:
http://thunderstoneaudio.nav.to/
http://groups.yahoo.com/group/Thunderstone_technical/
Old 14th May 2003, 03:18 AM   #134
Tomek is offline Tomek  United States
Question CD Rom and Nonoz
Accordingly to information which I found on the web, digital output from CD Rom is in TTL format. I want to use Cd rom as a transport. The circuit which converts TTL signal to SPDIF contains 1:1 transformer and 74HC04 chip ( is taken from this website: http://www.epanorama.net/documents/audio/spdif.html ).
DAC which I want to build is a Fedde's NonozII. I thought to put conversion circuit inside of CD Rom enclosure. I would also like to use this DAC with other transports, not only with my CD rom. What would be the best in this situation? Should I put another transformer inside of the DAC?
Old 14th May 2003, 05:09 PM   #135
Default Re: Good Low Noise PSU
Hello,
Thank you boys.
Pascal.
Pascal
I suggest to at least look athis tool
http://www.duncanamps.com/psud2/index.html
and you may consider posting in a tube related section of this community
I prefer passive supplies, or shunt regulators
Guido Tent
www.Tentlabs.com
Nonoz DAC page fedde Digital Source 62 24th June 2011 11:34 PM
Chill-amp II page fedde Chip Amps 7 22nd February 2006 09:30 PM
Nonoz III DAC fedde Digital Source 4 17th January 2004 03:57 PM
my new web page Fred Petersen Swap Meet 12 23rd May 2003 04:49 AM
Page generated in 0.09561 seconds (74.63% PHP - 25.37% MySQL) with 11 queries
