| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
One quick question.
Could I replace LT1028 used in analog output stage with virtually any similar opamp. I have a few opa2604, opa2134, opa627 or ad797, ad8001. |
#2 |
I thought it would be very simple (not for me). Is it so simple nobody wants to answer ?
#3 |
diyAudio Moderator Emeritus
When you show the circuit someone will be able to answer. It's like asking which boat is best to cross the water. Which water ? Ocean or lake ?
You see ? So what circuit / which cdplayer/ what rail voltages etc.
It's only audio |
#4 |
Electrons are yellow and more is better!
Since he is refering to a DAC which isn't released yet I think he means the circuit in the datasheet
PCM1792 and DSD1792 with 132dB SNR The mysterious NE5534 in the datasheet of PCM1792 Datasheet here http://www-s.ti.com/sc/psheets/sles069/sles069.pdf Opamp question. The filter should be low noise and low distortion if you really want to take advantage of the high performance of the DAC. See also my wonderings about the weird opamp choices in the datasheet in on eof the threads above.
/Per-Anders (my first name) or P-A as my friends call me |
| pcm1792 output circuit using single power supply? | cbriere | Digital Source | 1 | 10th April 2008 09:07 PM |
| I/V stage for balanced current out DAC (pcm1792/94/98) | 00940 | Digital Source | 16 | 9th October 2004 05:09 AM |
| pcm1792 I/V stage layout | BrianGT | Digital Source | 26 | 24th January 2004 11:56 AM |
| Page generated in 0.08506 seconds (71.83% PHP - 28.17% MySQL) with 10 queries |
