| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello
I've built a few modular synths, headphone amps, and other relatively easy stuff over the past year, and now I'm feeling ambitious enough to build a D/A converter. I have a very minimal amount of knowledge of how they work (in detail), but plenty of knowledge of their function (and digital audio in general). I'll need s/pdif input, up to 24/96 conversion, and a headphone amp. I'll be using the s/pdif out of a Presonus Firebox with Live and Logic. So, with soldering experience, lots of time, and a couple hundred bucks, where do I start? |
#2 |
#3 |
I think that might be too elaborate for a first DAC project..
I was thinking something more like this: http://sound.westhost.com/project85.htm What do you think? |
#4 |
Assuming you can get the parts, that is as good a place as any to start but for something more recent and a little more complex try these.
Ezdac threads: My first DAC attempt...PCB help needed EZDAC is singing now!!! Microdac thread: Micro DIR9001 + PCM1794A DAC |
#5 |
The EZDAC is surprisingly easy to build (once you perfect your SMD skills, that is)
OK, the EZDAC is conceptually very easy to build....the execution requires patience, a steady hand, a very fine soldering iron tip, and a temperature controlled iron. But hey, I built one, and that's saying something. |
| building a sub box | shovelhead 93 | Car Audio | 3 | 22nd February 2009 11:19 PM |
| Box Building | thunderlaxton32 | Car Audio | 3 | 29th September 2007 01:44 PM |
| Building: Need Help | ICARE | Tubes / Valves | 19 | 6th June 2003 11:32 AM |
| Page generated in 0.07584 seconds (71.70% PHP - 28.30% MySQL) with 10 queries |
