| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I came across a TDA1541A DAC that uses -5V, -15V and +6V (VDD). TDA1541A has a maximum of +6V for VDD and :-
1. What is the advantage of pushing it to the limit? 2. Is there any disadvantage by pushing the VDD to its limit? Picture of PCB ![]() The 7.3V is the voltage when TDA1541A is not inserted to the socket. |
#2 |
2. Burn in hell ( the chip ) |
#3 |
This is actually my DAC and I have been using it for nearly 18 months now. I just discovered this and when I wrote the seller, he says it is their design but without telling me why. The DAC is a little bit warm (30 degree C) after a full day's operation. The sound is great too.
Can anyone give me a glue? |
#4 |
According to the datasheet of the TDA1541, the absolute maximum ratings are:
VDD: 0 to +7 V VDD1: 0 to -7 V VDD2: 0 to -17 V Exceeding these will most likely result in significantly shorter life. These are not recommended values, though. That's why typical values are lower. 6 V would just be in the recommended range, so that should be fine. Sometimes designers need to take advantage of the margin between recommended and absolute maximum ratings to avoid a more complex or expensive solution. Other than that, I see no advantages. |
#5 |
The voltages in the Marantz CD-94 are +5V, -6V and -13.5V. The DAC chip is a bit hot, but no issues. In the Cambridge Audio CD-3 the DAC chips are provided with heatsinks.
| What's the advantage of E-linear | Michael Koster | Tubes / Valves | 34 | 30th August 2009 01:38 AM |
| Advantage of a FET-BJT CCS vs BJT only | Bitrex | Tubes / Valves | 2 | 10th June 2009 03:01 AM |
| Another advantage of IB | mashaffer | Subwoofers | 2 | 15th September 2007 04:57 PM |
| What advantage from short arrays? | Dumbass | Multi-Way | 15 | 17th November 2005 10:04 PM |
| advantage preamp | seahag | Chip Amps | 9 | 4th October 2005 01:23 AM |
| Page generated in 0.09722 seconds (76.44% PHP - 23.56% MySQL) with 10 queries |
