| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I had a silly idea the other day about using my Denon DVD-757 in combination with a Xilinx Spartan 3an starter kit to send the raw PCM/DSD data over ethernet to a computer.
Well apparently this idea got out of hand and is now semi-successful. Initially I thought I would have to solder leads to the PQFP chip (the BB DSD1608 part) in order to recieve the PCM and DSD data. Apparently there exists a through-hole copper connector for the following: _PCM_ PDATA1 (all 4 stereo serial connections) PDATA2 PDATA3 PDATA4 PBCK (pcm bit clock) PLRCK (left/right pcm clock) _DSD_ DSD1-8 (1-bit for each channel) DBCK (dsd clock) Ive tested each of these connections in Chipscope Pro and they are all valid depending on what type of disc I'm playing. Heres a crappy shot of the PCM section with labeled pins: ![]() (sorry about the image size) I plan on connecting all pins for pcm and designing a vhdl module for transmitting the data to the ethernet interface. On the PC side, I will used winpcap in c++ to grab the raw data so I don't have to worry about the headers and latency. Another gratuitous fun shot: ![]() Anyone have an opinions/ideas? |
#2 |
Don't know anything about this stuff but it sounds interesting, so good luck.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#3 |
#4 |
Looks like I went and nuked my spartan3... Waiting for a replacement board. Should give me time to write a vhdl module for buffering and transmitting data to ethernet.
#5 |
There are lots of software tools to work with PCM data available. But what can you do with DSD? Are there tools available to work with DSD?
Since a DVD ROM drive won't recognize a SACD, I have never had the chance to edit or manipulate DSD data. |
#6 |
This is true, I don't think many people have had the opportunity to work with DSD yet. I think the simplest way to do this is to use a low-pass (averaging) filter followed by decimation of 64. I am assuming all DSD signals are 44.1khz x 64 = 2.822mhz, but I am probably mistaken. The bit resolution could probably be varied depending on how the filter is implemented.
I found a nice website that goes over alot of the basics: http://www.beis.de/Elektronik/DeltaS...igmaDelta.html |
| Sony NS500V SACD modification project | dorkus | Digital Source | 36 | 5th April 2010 10:53 AM |
| A SD/USB/Ethernet transport | jkeny | Digital Line Level | 8 | 25th September 2009 12:20 PM |
| Hackers wanted for Ethernet DAC team project. | peufeu | Digital Source | 58 | 2nd January 2008 09:37 PM |
| Ethernet with cat5E to USB-Dac ? | lykkedk | Digital Source | 0 | 1st May 2007 06:15 PM |
| Page generated in 0.08122 seconds (75.48% PHP - 24.52% MySQL) with 10 queries |
