Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
strange distortion on one channel of cd player
Old 7th December 2008, 07:13 AM   #1
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Default strange distortion on one channel of cd player
I have a marrantz cd6000 which is modded.
I recently noticed that when soundtracks get loud, I get a strange distortion on one channel. If I turn the volume of the cd player down, the distortion goes away.
I put a scope across the output of the affected channel, and it appears to sort of clip, its a very faint line across the top of the signal, but its not hard clipping in that signal does appear to go higher. This faint line when clipping dissapears if I turn the volume down and the distortion stops.
I wondered if it was oscilating on one channel but I dont think it is. I changed the opamp with a spare (lm6172) and no difference.
I checked for dry joints but it really looks in good order.
The other strange thing is that the headphone amp doesnt have this distortion at all, regardless of volume. If you look at the cd6000 schematic, the headphone output comes after the opamps and hdam. This only leaves the muting circuit which is in tact (without output caps). Is it possible its the muting circuit and if so, whats the strange clipping on the opamp output.
any comments appreciated.
I have checke
Whats also strange
Old 8th December 2008, 04:41 AM   #2
please ignore last two lines of my post. No one out there have any suggestions?
Old 8th December 2008, 07:00 AM   #3
poynton is offline poynton  United Kingdom
poynton's Avatar
Try removing the muting by lifting the leg of the transistor .
Also restore the output caps as a temp. measure.
Sounds like one of the muting transistors could have gone 'leaky'.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 8th December 2008, 07:23 AM   #4
thanks Andy,
Ill give it a whirl and see what happens.
Old 8th December 2008, 03:39 PM   #5
anatech is offline anatech  Canada
anatech's Avatar
Hi Luke,
These parts will test fine out of circuit, removing them is the only way to test them.
Now for the good news. These are special transistors made specifically for muting. You must use the same part number as these have a much higher E-B breakdown voltage. One example of an older number is 2SC2878.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 9th December 2008, 08:00 AM   #6
Hi Chris,
thanks for the tip. I will remove them first and see if the noise goes away. If it does I dont know if its worth replacing them. Freight alone will be rediculous for these. Perhaps I can source them locally.
Perhaps I get time in the weekend to check it out.
Old 9th December 2008, 09:58 AM   #7
poynton's Avatar
There is an alternative which does not rely on "special" transistors and that is to replace the muting with a relay (as used in the original Philips players before the beancounters got involved)
Andy
Old 10th December 2008, 02:35 AM   #8
anatech's Avatar
Hi Luke,
You really need to have some kind of muting in there.
Hi Andy,
That is the way I would go for sure! Not knowing how much Luke is comfortable handling had me hang back on that suggestion. You are talking about mounting the relay acceptably and modifying the drive circuit possibly. The high sensitivity relays would be the ticket there. The communications types sealed with a nitrogen gas fill would be my choice.
-Chris
Old 17th December 2008, 08:03 AM   #9
Hi Andy and Chris,
I took the transistors out and one was leaky. I replaced the muting on my cd67 with relays. I know I kept them in one of my many parts bins (all new stuff organised replaced parts dumped in various bins) I finally found the parts and they were the same. I replaced the faulty transistor and now Im away
As for fitting relays, Im a bit over modding players for now, I tend to find they spend more sprawled over the workbench than playing music.
Again thanks for all your great help!
Old 17th December 2008, 10:54 PM   #10
anatech's Avatar
Hi Luke,
Good show!
Most defective muting transistors I have pulled over the years measure fine for leakage. That's why I test by replacement these days, although I do confirm the fault first.
I hear you on the mod thing. Same experience here.
-Chris
strange distortion on one channel of cd playerHide this!Advertise here!
Strange buzz in only one channel ClaveFremen Chip Amps 9 11th January 2009 12:58 PM
strange noise from right channel keyser Everything Else 15 2nd May 2005 10:14 PM
Strange distortion problem Adam M. Chip Amps 15 23rd August 2004 01:37 AM
Accuphase DC-81L D/A conv - strange distortion on right ch. (service manual anyone?) Spyhunter Digital Source 0 9th January 2004 05:04 AM
strange GC Distortion.... sa_schulz Chip Amps 19 6th August 2003 05:41 PM
