Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th November 2008, 02:14 AM   #1
robo is offline robo  Hong Kong
Default what can we do on PHILIPS CD880?
hi,guys...
well here is those things i have done on my CD880.just a example.
i did it step by step:
1,i took those chips off the board from CD880.empty its land.so i can see the good layout from PHILIPS.learn on it.i don't want to make to much change.
2,used PROTEL(a eletronic design software well known) to make a new layout basic on the CD880 board.off caurse we can add some our own ideas on it.
at this step,we need some test if we want to add something new.just like the new SPDIF out circuit basic on DS26LS31,and new circuit for RESET,and so on.as you can see,what i need is just a SPDIF output which is good enough.so i also added a re-clock use 74HC74.
3,after time check on the layout.it's time to make the new layout into PCB.we need help from a PCB maker.
4,about 1 week,i got the PCB.well....i can't wait any more.i have been waitting for this moment for 2-years.
5,solder all components we need on it.beginning from SMD to DIP......
6,checked again if i had done some wrong when soldering....make sure every thing were OK.
7,time to test my work.....i have to say,i have tested many new PCB,but this time i still felt nervous....hope i was lucky!
8,ha..ha....
it worked......it worked....
Old 26th November 2008, 02:20 AM   #2
the most valuable part for A PHILIPS CDP
Old 26th November 2008, 02:24 AM   #3
i soldered it step by step.i can get power for its own power board first.just want to make it easy...
Old 26th November 2008, 02:27 AM   #4
i was so lucky....it worked well....of course it's time to solder the rest components....
Old 26th November 2008, 02:28 AM   #5
finally i finished it...looks easy?
Philips CD880 mods Zoran Digital Source 85 11th January 2009 09:45 PM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 12:43 PM
what other mods should i do? Philips CD880 loomis Digital Source 6 28th May 2007 07:54 AM
Philips CD880 or 960? Skorpio Digital Source 1 11th November 2006 08:57 PM
Help: EPROM of Philips CD880 LeoJar Digital Source 6 7th February 2004 05:46 PM
Page generated in 0.09403 seconds (78.51% PHP - 21.49% MySQL) with 11 queries
