| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello,
I own a Musical Fidelity CDT Player. It has a signal transformer in the begining of the tube output stage (see enclosed pincture. It's is a cube shielded with a metal sheet). One channel fails. Temporary I have solved the problem connecting the stage without the transformer. I have inserted one capacitor and one resistor (the signal was too high) in the signal path and the player works again. I would be interested in the service manual of schematic. Does anyone know the transformer specifications?. Does anyone know what is the CD mechanism? Has anyone modified this CD player? Thanks for your help. |
#2 |
I think the CD mechanism is a Sanyo SF-90 5/8. Does anyone know any details about the transformer?.
#3 |
Is it definately a transformer? Would not surprise me if the shield was the hiding place for some op amps.
WRT modding, these units are notoriously quirky, if it works otherwise, I would leave it alone. |
#4 |
No. I think the shielded "brick" has two transformers inside. It has only three input terminals and three output terminals. One is ground and is common.
My "brick" has one channel faulty. I have tested the other one connecting a sinus wave signal and checked the output with an oscilloscope. The output signal is lower than the input signal. Maybe the only purpose of the transformer is to supress any DC offset. Without the transformer and inserting a capacitor in the signal path (before the output stage), the tube oputput stage and the CD work. |
#5 |
Hello !
I bought this player and I like its vitality, I prefer it to my Arcam CD72. It's hard to find informations on the Musical Fidelity CDT, also known as 'Musical Fidelity PAN' (try this in google) I do not know anything in electronics, but may be this link may interest you, or try contact 'dht' : http://translate.google.com/translat...istory_state0= i speak english like a frog, sorry
#6 |
This is the power supply schematic published by dht
#7 |
and the output stage schematic
#8 |
The trafo picture. The DC resistance values are;
R primary = 5.93Kohm R secondary = 86.40Kohm The output signal/input signal ratio is aprox 0.7 |
#9 |
contax,
unfortunately I dont have the service manual. I have only these two schematics posted on audiostereo. Maybe tomant could help you, send him a private message (PW) via audiostereo. If you want to tweak the CD I suggest you to bypass the trafo and NJM4558 opamp. I can send you a LC7881 datasheet. dht |
#10 |
Hi contax!
Do you solved your problem? I have a Musical Fidelity "PAN" and my one has the same symptoms as yours. Sometimes the faulty channel works fine. When i heat up the "brick" it mostly works. Can you help me? Best regards |
| musical fidelity a3cd player | mpg2971 | Solid State | 2 | 15th July 2008 05:38 PM |
| Musical Fidelity A3 CD Player mods? | itzibitzi | Digital Source | 15 | 1st September 2007 08:42 PM |
| Musical Fidelity A3 CD Player Clock Frequency? | 300_baud | Digital Source | 19 | 16th June 2005 08:33 AM |
| Musical Fidelity- Do you know it well? | SugarMedia | Solid State | 2 | 26th February 2005 01:11 AM |
| Musical Fidelity PR-70 | dinamic1 | Solid State | 0 | 29th April 2002 08:41 AM |
| Page generated in 0.11728 seconds (81.42% PHP - 18.58% MySQL) with 11 queries |
