What CDP/DAC's used the TDA1541 ? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 31st March 2003, 04:55 PM   #11
guido is offline guido  Netherlands
guido's Avatar
Dont forget there is an 1541 and there are 1541A's (normal,s1,s2)
So not all players are interesting. E.g. my cd650 has the 1541.
The A version is supposted to be better.
Greetings,
Guido
GuidoB
Old 1st April 2003, 01:48 AM   #12
Circlotron's Avatar
I have an old 8x CD-ROM drive (1996) with a pair of them in it. More likely to get an old one of those for free. People throw them out mostly because they are not fast enough, not because they have stopped working.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 1st April 2003, 05:27 AM   #13
diyAudio Moderator Emeritus
jean-paul's Avatar
If the CDrom is made in 1996 it will probably have TDA1543(A) and not TDA1541A.
Old Aristona, Erres and Magnavox cd-players had the chip as well. Sony CDP-M95 and CDP-950 have it. Old Arcams have it.
I wouldn't recommend the non os mod just like that. You will have to change the whole output circuitry when you do. Most don't do that and the endresults of removing SAA7220 will be disappointing after all. Better make an external non os DAC instead and let the player be 4 x Fs.
Decouple the SAA7220 very good. Preferably OSCON or the like. Stupid but effective mod: solder a solid core wire over the ground track on the main PCB !
Grounding is not the strongest point in old Philips players and soldering the wire will make a cheap and very effective mod...
It's only audio. Member of the non modular PCB design committee
Old 1st April 2003, 11:28 AM   #14
Ah yes I should have said 1541A!
Still I have a CS8412 and fancied non os'ing something. I think I'll look for an old marantz and then play around.
Cheers Guys
Old 1st April 2003, 09:07 PM   #15
jean-paul's Avatar
If you fancy non osing something TDA1543 will be OK for a start and it'll be cheaper, much easier to find and easier to build
And it'll be very good !
Old 3rd April 2003, 09:09 AM   #16
aesse54 is offline aesse54  Italy
Here are some more:
Orelle CD100
Philips 465, 650
Revox B226 (1541AS1)
Rotel 855 (1541AS1)
Sudgen SDT-1 (1541AS1)
alessandro
Old 26th May 2004, 05:51 PM   #17
DJMC is offline DJMC  Spain
Default More 1541s
The philips cd820 has a 1541A inside. One more in the list!
Old 27th January 2005, 08:03 PM   #18
ash_dac is offline ash_dac  United Kingdom
Mission PCM7000 has a socketed tda1541
Old 10th February 2005, 01:20 PM   #19
Carondimonio's Avatar
Hi all,
found this List .
Bruno
Old 31st March 2005, 10:25 AM   #20
tubenut is offline tubenut  South Africa
tubenut's Avatar
What is changed/should be changed to the output stage of a 1541A based player? The filters? How? Messing with a mission PCM II at the moment. Non os done and I think I like it apart from a certain hardness occasionall shrill sound in the highs on complex material.
Do you mean the ground track below the SAA7220? IE, you solder it on top of the track to create a chunkier mass of earth plane perhaps with lower resistance?
G
Tda1541 R1?? HeadSh0T Digital Line Level 21 12th January 2010 01:25 PM
It's my TDA1541 dac purer Digital Source 11 25th July 2006 07:19 AM
Fs Tda1541 S1 Bernhard Swap Meet 2 14th June 2006 06:59 AM
Copyright 1999-2017 diyAudio
