attenuation using I/V - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th October 2008, 05:30 PM   #11
Interesting looking attenuator thanks for posting it. I see from the connectors that it is an RF attenuator. Is it stepped or continuous? Is it a linear taper? What is it and where can I get one?
Dave
Old 15th October 2008, 05:34 PM   #12
David
you are right about the resistor quality.I have tried several,from top series caddocks to some cheap nonames,and i found the best sounding resistor to be some B.I thick film.Day and night diffirences.
Also,i was thinking the same thing you did,variable shunt resistor after the first tube stage,right before the second stage.
That is,redusing the load resistance of the first stage from 100K to about 1K.Have you ever tried it?
Old 15th October 2008, 05:53 PM   #13
My DAC active stage is a single-stage tube with a transformer coupled output. The output impedance is less than 1K. The schematic can be seen in this article, which also shows the attenuator on the input.
http://www.raleighaudio.com/active_output.htm
Dave
Old 15th October 2008, 05:58 PM   #14
I see...
I am sure if you use a parallel resistor to the stepper you won't get any pops.The pops are made because the dacs is loaded with a very large resistance for a very short period of time.It is a known problem to me.If you have a parallel resistor of the same value you won't get these pops.Yet,i will try soon and give you the results.
Stavros
Old 15th October 2008, 06:20 PM   #15
Thanks Stavros,
I am looking forward to hearing about the results of your experiment.
Dave
XLR to RCA with attenuation pad. KOL69 Everything Else 1 24th April 2008 11:10 PM
hum attenuation AndrewT Power Supplies 3 2nd July 2006 09:12 PM
Attenuation argonrepublic Analog Line Level 5 23rd August 2005 07:22 AM
10 dB attenuation box june Parts 2 20th July 2004 04:07 AM
Attenuation Nappylady Multi-Way 3 18th February 2003 12:07 PM
Copyright 1999-2017 diyAudio
