Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th October 2008, 04:35 PM   #1
Default TDA1541A Output Coupling?
According to one DAC manufacturer's website there are gains to be made depending on how you couple the output stage of your TDA1541 DAC. It goes onto say,
transformers as coupling devices are sonically superior to capacitors but, as good as they are, a direct coupling can be still better.
Using the output stage on the TNT website as an example you can see the standard approach of coupling with good quailty capacitors (i.e. C405, C406). Now to transformer couple I understand the concept of just replacing C405 and C406 with the proper coupling transformer from Sowter or the like. What I don't understand is the method of direct coupling mentioned above and it's pros and cons.
Dan
Old 6th October 2008, 05:05 PM   #2
Bernhard's Avatar
I would try a resistor from Iout to a quiet V+ or V- , don't remember, for sure someone can help you...
Old 6th October 2008, 06:09 PM   #3
Pars is offline Pars  United States
Pars's Avatar
Something like rbroer's less simple I/V stage for an example of direct coupled...
Old 6th October 2008, 06:12 PM   #4
Here's an explanation (I think) of a direct coupled output.
Direct coupled outputs provide incredible bass enhancement. There are no capacitors anywhere in the signal path, resulting in a linear response all the way down to DC (0 Hz!). An actively maintained low output offset is achieved through a DC Servo Loop. The DC component of the output signal is continuously corrected to maintain zero volts DC without the use of high loss and sound blocking capacitors.
Dan
Old 7th October 2008, 09:43 AM   #5
oshifis is online now oshifis  Hungary
A DC servo circuit is not equivalent with a DC coupled circuit. There is a pole somewhere... See Post #11 of the Less simple I/V thread.
It is possible to DC-couple the TDA1541A by injecting 2 mA (slightly adjustable) current into its output.
Old 7th October 2008, 02:43 PM   #6
Pars's Avatar
What? The output does not go through a cap or anything... it is DC coupled. A DC coupled circuit is the only instance I can think of where you would even want to use a servo...
Old 9th October 2008, 12:29 PM   #7
There is always a capacitor in the servo integrator amplifier so that the loop gain of the DC error signal is very high. The loop gain will fall above a certain frequency. If you remove that capacitor, the audio signal will be also considered as an error signal and will be nulled at the output.
Since there is a pole, there is also phase shift. I have a feeling that the type and quality of the integrating capacitor does matter, just like that of an output coupling capacitor. The only difference is that it is in the feedback path, not in the forward path. But I am interested in others' opinions.
Transformer coupling and output for SS mashaffer Solid State 1 17th May 2005 08:47 AM
Do I always need an output coupling cap? Dominique Solid State 11 25th February 2005 10:35 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
output coupling caps, yes or no? catrafter Digital Source 1 8th May 2003 02:34 AM
Page generated in 0.09158 seconds (81.73% PHP - 18.27% MySQL) with 10 queries
