Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 29th September 2008, 10:34 PM   #11
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
have you any (0,5:1 or 1:1 or 2:1 ) small signal xformers ........ ?
what's needed is anything between 1k to 10k primary impedance
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 29th September 2008, 11:44 PM   #12
Stones is offline Stones  United States
Stones's Avatar
Originally posted by CeeVee
Reciever is Cirrus Logic CS8420Cs.
I don't understand why you need the reciever, could be worth while if you can remove it.
As for the output stage a real easy thing would be to try the D1 output stage.
Old 30th September 2008, 12:15 AM   #13
Zen Mod's Avatar
ceevee mention receiver just as info ;
hehe - even if I think that he certainly need that receiver , for functional cd .........
D1 - in original - if used for this ,balanced out DAC........ sorta sad/half solution - using just one I leg of DAC ;
yes , with D1 he'll have bal out ( needed for his UGS based preamp , but still just unbal input in D1 ;
makin' balanced in D1 , or anything like that - certainly messier than plain resistive I/V with xformer , with or w/o output buffer .
if I calculated correctly - 1738 gives enough voltage directly for line output ;
while we are at it ........ CeeVee - can you make small test :
-toss out all OPamps ;
-put 1k2 parallel with 4n3 - between + and - I outputs (DAC pins 17 and 16 , 25 and 26 ,respectively ) ;
-desolder one side of resistor placed across I/V conversion/filter OPamps (first to DAC);
-route output signal (via 3u3 in each (+/-) leg to output ;
-just listen - if you like what you hear in that raw test , we are on something
I hope that I'm clear enough , without attaching schmtc
edit:
attached test schematic
Old 30th September 2008, 01:24 AM   #14
Stones's Avatar
I think you miss the point, If you need a receiver for it to work, you might as well consider an outboard DAC. If not for the separate supplies alone then consider that you can mod it without risking loss of music while playing with it and having a direct baseline (however good or bad) to judge against.
Old 30th September 2008, 01:36 AM   #15
Zen Mod's Avatar
thread title is ( at least for start) "upgrade output ....... "
mentioned receiver is existing part in sayed CD player ;
I really don't care about receiver issue , at least in this moment .......... considering intentions of original poster
Old 30th September 2008, 01:42 AM   #16
Stones's Avatar
I have finally managed to get both coherence and seriousness from you Zen Mod.
Old 30th September 2008, 01:47 AM   #17
Zen Mod's Avatar
Old 30th September 2008, 02:33 AM   #18
gbyleveldt's Avatar
The CS8420 is not just a tranceiver but an upsampler as well...
The walls between art and engineering exist only in our minds - Theo Jansen
Old 30th September 2008, 09:20 AM   #19
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Thanks guys for a very lively discussion, and yes the as ZM says i just mentioned the reciever as info, to transmit a picture, so to speak.
It is indeed an upsampler as well, 96k/24bit.
and as ZM says' the original idea is to upgrade a bad DAC output stage, but it could go further if the conclusion/test show that that is the way to go....and ZM is willing/interested.
For myself i'm certainly open to sugestions that will get this " cookbook" CD player to produce decent sound.
For now i'll do the testing you sugest ZM, later today ...for now the guys flying the planes need my atention.
edit: ahhh the transformers,...no i don't have any, since i will need them what do you sugest i get ?
Old 30th September 2008, 09:41 AM   #20
Zen Mod's Avatar
make a test first ; if outcome is positive - you'll have not just one choice
Nad s100 without chassis FlexQ Swap Meet 8 16th February 2009 09:16 PM
DDDAC 1543 MKII distortion on analog output zdr Digital Source 16 3rd August 2008 11:09 AM
Mod SHANLING CD-S100 fred78 Digital Source 0 4th January 2008 11:18 AM
FS: SHANLING CD-T80UK with A+ UPGRADE - EU! cartman Swap Meet 0 22nd October 2007 07:04 PM
Page generated in 0.12055 seconds (78.67% PHP - 21.33% MySQL) with 11 queries
