| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 |
Hello everybody!
I'm new in this forum, so forgive me for all my falses!! I buy PLL1707 ,so i can produse a 27MHz clock from a crystal(27MHz)! I think i do all the necessary connections but i take a 9MHz clock as output,in PINS MCKO2 or MCKO1. Could you explain me why this happens,or what have i connect false? My connections are: FS1=1 FS2= 1 CSEL=0 SR=0 Thank you beforehands! |
#12 |
In page 13 of the PLL1707 data sheet, FS1=1 and FS2=1 is not defined. Could it be the cause of your problem?
#13 | |
The regulator is about 60nV/SqrrtHz, not bad, depending on power supply rejection it may be enough. Honestly, the clock is way too complex. First you generate 27 MHz, then a synthesizer makes 11.2896. Keep it simple ! You may re-use the 11,2896 MHz crystal and build a standard Colpitts oscillator, with a simple style HC04 inverter as a slicer and end up way better than the clock you propose here. best |
#14 |
I just opened 2 long 4 pin rectangular cristals, one is 33.8 Mhz (from a soundcard) and other is now zero Mhz, (i broke the small cristal itself!)
In it is a small cristall, suspended on 2 springs driving a smd 74HCU04 on a ceramic pcb. The other has a TI031X 301145 chip, couldn't find what chip it is. Maybe its most simple to buy (or find from scrap) such a VCXO cristal and fit it in CDP with a decent PS. Most simple solution, but sound improvement? Have a awfull 2000 ps jitter producing cheap DVD/VCR player, it needs a 27Mhz cristal (to Ziva 4.1 chip, the dvd mechanism uses a 33.8 Mhz cristal) Maybe i could try this. The Ziva would benefit most i think.
Daisy Bell |
| CS8412, PMD100, PCM63, onboard clock + [word] clock output implementation | stolbovoy | Digital Source | 7 | 3rd December 2004 07:18 PM |
| Clock radio speaker enhancement "project" | ukram | Everything Else | 0 | 20th September 2004 09:46 PM |
| Kwak clock versus Tent clock | rbroer | Digital Source | 22 | 21st September 2003 01:20 PM |
| Quality pots with "notches" at 12 o clock? | massappeal129 | Parts | 5 | 3rd April 2003 09:14 PM |
| Page generated in 0.08764 seconds (69.75% PHP - 30.25% MySQL) with 11 queries |
